Author Topic: The VIC with resonant cavity project by Steve..  (Read 111245 times)
0 Members and 48 Guests are viewing this topic.
« Reply #320 on: October 19, 2016, 23:06:37 pm »
Hello Steve.
The transformer relationship of impedance ratio to turns ratio is:
 Npri/Nsec = √Zpri/Zsec
First you need to know your impedance of the  circuit on secondary, and I THINK that you need to calculate it in the lowest value that it can achieve. obvious that frequency will change the overall impedance.
Get the resistive value of the coils, and use the 78.54 or 80 as the cell resistance, sum all and you have the circuit resistance.
Some people said that at resonance the circuit is pure resistive(Russ and Ronnie Walker).
Since you get the impedance of the secondary network, wind your transformer according to it.
BE AWARE: Transformers are not simply turn ratio!
Forget about Meyer primary resistance, it doesnt mean anything, only if you have the same core and the same wire, otherwise forget it.
X blade, thank you.
I re read yr post and i think this is a good advise!
cheers
« Reply #321 on: October 20, 2016, 09:52:51 am »
Just thought i would share a scope shot.
Can you tell us what you show us here, from a setup point of view?
« Reply #322 on: October 20, 2016, 09:54:42 am »
Load calculation.
75.5 ohms and 71 ohms for chokes and 78 ohm for cell + diode 1 ohm makes 225.5 ohms total load resistance.
« Reply #323 on: October 22, 2016, 17:23:22 pm »
a view on Meyers driver circuit for the primary coil.
Ask yourself why he made it like this....
cheers
Hi Steve my lack of knowledge of electronics needs a little input.
I have a hard time to see how the flow works.
Can you explain this to me.
Is this the primary coil?
Should it be on the other line from the 3005? Not from the Tip120.
« Last Edit: October 23, 2016, 16:56:02 pm by komtek »
« Reply #324 on: October 25, 2016, 01:26:33 am »
Just a thought or information with the impedance . ...Puharch adjusted his electrodes to have a specific voltage to current ratio,somewhere I've seen impedance is the voltage to current ratio.It goes into measuring the conductivity of the water.
Are you having success with the matching yet?
« Reply #325 on: October 28, 2016, 04:12:28 am »
Steve and others, I am giving out a lot of information on how Stan's fuel cell works over at RWG forum You guy's may want to go check it out.
http://open-source-energy.org/?topic=2785.0
« Reply #326 on: October 28, 2016, 16:19:20 pm »
Just thought it may help people in some way. It's there if people want to check it out. Thanks
« Reply #327 on: October 28, 2016, 23:00:09 pm »
It's really nice to see someone that can explain stuff and feel the rightness of it in such a simple way,good job !
« Last Edit: October 29, 2016, 06:45:02 am by Newguy »
