Author Topic: The VIC with resonant cavity project by Steve..  (Read 111182 times)
0 Members and 51 Guests are viewing this topic.
« Reply #272 on: May 23, 2016, 00:51:18 am »
test
My new testlab...
« Reply #273 on: June 28, 2016, 20:06:52 pm »
Dear Fabio and Kevin and others,
Maybe you remember that i was in the middle of a deforce of my wife. Well, that part is done. We sold our house, as ni one of us would stay.
So, now i moved in by my new girlfriend in Germany.
Yes, i moved countrys....pfffffff
Not easy, btw. A culture shock....hahahahahaha
Not having my lab was a bad feeling.
Today i build it almost up again.
As you can see on the pictures, is my whole collection of materials and tools in boxes.
The coming days i will put my meyer cell etc back on my new bench!
I am also looking for parts for my version of the Anderson setup.
Well, now you know why my progres was sooooo slow.
cheers
« Reply #274 on: June 28, 2016, 21:21:30 pm »
more pics
« Reply #275 on: June 29, 2016, 01:14:40 am »
Good luck with the new life Steve....3 times i divorced....allways a hard thing to go thru.
« Reply #276 on: June 30, 2016, 13:41:31 pm »
Nice move my friend.. good moment of changes! wish you luck too with your new lab!
« Reply #277 on: September 18, 2016, 18:21:31 pm »
X-blade and others who want to join in:
I measured my cell in a dry state. I removed the destilled waterand dried the cell.
My 4 cells measure between 0.043nF and 0.050nF.
So what is the capacitance for these cells with destilled or tap water?
Dielectric constant of water at 20 degrees celcius is 80.1
If i multiply 0.043nF times 80.1 i get 3.4nF or 0.050 times 80.1 i get 4nF
Distilled water having a conductivity of 0.5 uS/cm (resistivity of 200 kOhms /mm)
(Tap water having a conductivity of upto 800 uS/cm (resistivity of 125 Ohms /mm)
Salt water having a conductivity of upto 56 mS/cm (resisitivity of 1.8 Ohms /mm))
If i would go for the famous 42.8khz as resonance frequency, my coils should be 3000uH in totall?
Calculation:5nF + 200kOhm resistance + 42.8khz makes a totall inductance of 3000uH.
Please shoot if my calculations are not correct.....
cheers
« Reply #278 on: September 18, 2016, 18:57:16 pm »
Hey bro is your cell the standard 4 inch rod with windows and the 2,75inch tube?
mine measures 1nf with zero ppm water and without is very low if i remember well around 10pf
are you sure your meter is ok:? ?: did you zeroed it?
the calculation is correct this form however  don't know about those numbers sources...
cheeers
« Reply #279 on: September 18, 2016, 20:39:57 pm »
cheeers
Dude, of course it is the standard Meyer type lengths.
My meter stands on the 2nF measurement option, which is the smallest option it has.
Then it measures 0.043 = 43pF
Something wrong here?
I still have some new / un used ones in a box. Can try to measure those if needed.
DOnt forget that the cell has been submerged for month with destilled water..
Maybe thats the reason?
Or yr measurements are not ok?  ;) ;) ;) ;)
Any body else?
« Last Edit: September 19, 2016, 10:33:35 am by Steve »
