Author Topic: ALTERNATOR  (Read 52694 times)
Re: ALTERNATOR
« Reply #16 on: August 28, 2010, 08:08:34 am »
Ok now just look and cry
Re: ALTERNATOR
« Reply #17 on: August 28, 2010, 08:31:03 am »
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA  :'( :'( :'( :'( :'( :'( :'( :'( :'( :'(
Sebos is so smart that he mathematically analyzed the circuit , it works , it has been confirmed . Ion goes there , electron goes there , left to right , right to left , OMG I am a genius , it will work , I am sure of it . This is pure scientific genius . Cant you see that this works , it should be obvious that it does , it should be obvious to anybody .
let me save this pic and put it in my usb key , then insert my key in my faraday cage to protect it from EMP destruction .
« Last Edit: August 28, 2010, 08:48:43 am by Dankie »
Re: ALTERNATOR
« Reply #18 on: August 28, 2010, 08:34:54 am »
Did you understood the principle at least?
The ions become electricity. Generated because of the force (voltage does perform work)!!! is like having two transformers with diodes in opposite directions, driving a set of 9 tubes in series (isolated ground)
I'm sure that anyone have never tried this!!! =)
Because there is no meaning, if you don't understand the ions, you will never consider this way.
There is a conventional current flowing witch creates the voltge field and at the same time in counter direction there is another current witch is the ions (they act like a back emf) If you create a path where they can discharge isolated from the first circuit you can turn of the back emf of the ions allowing huge current to flow. Now i understand also why meyer coated the outside of his tubes and inside of inner tubes...
(discharge the ions mean generate h2 and o2 molecules)
Turn of the covalent bounding ...
I'm really sure that this will work.
« Last Edit: August 28, 2010, 09:56:27 am by sebosfato »
Re: ALTERNATOR
« Reply #19 on: August 28, 2010, 12:18:34 pm »
I am also very sure that nobody ever tried this... ;)
Are you gonna try this Fabio?
Re: ALTERNATOR
« Reply #20 on: August 28, 2010, 14:59:16 pm »
yes man
i'm just figuring out how to make the cell with less money possible
Every time i think i get more absolutely sure...
I'm going to use only the alternator and a small motor to drive it...
When resonance start the alternator will rise its speed because i'll discharge the ions on one of the phase windings.
I just also need to figure out exactly how to connect the alternator exactly
i know that the alternator have the phases different by 120° i guess thus i need to choose the right winding for doing the job.. . still not sure hwo to do this...
Re: ALTERNATOR
« Reply #21 on: August 28, 2010, 18:54:31 pm »
yes man
Maybe the following helps to make up yr mind.
I seen the ion spike on my scope. I even made a picture of it.
As soon as you use that charge coming of the tubes for example lighting a bulb, you extract
the power from the water, which you just filled.
Re: ALTERNATOR
« Reply #22 on: August 28, 2010, 19:24:30 pm »
Sebb,
I think you should try it with 2 sets of tubes first to prove the concept.
« Last Edit: August 28, 2010, 20:49:43 pm by yaro »
Re: ALTERNATOR
« Reply #23 on: August 28, 2010, 19:47:46 pm »
yes man
Yes steve i remembered that picture when i found this...
I worked all night on the alternator to separate its windings and i've just finished to assembly it. First of all i will make it become a motor... Than i will use the other 2 coils for develop the coulomb force on the water.. _Than when it will be working i will add a motor to mechanically turn the alternator and than i will use that winding to discharge the feedback of ions!!! this will accelerate the alternator without consuming force from the motor. I believe it can get self running... not sure...
