Author Topic: ALTERNATOR  (Read 53006 times)
0 Members and 17 Guests are viewing this topic.
Re: ALTERNATOR
« Reply #112 on: September 08, 2010, 06:23:18 am »
Hello guys i´m almost ready to turn on the power. I just need to connect to the car battery and the igbt drivers to its respective power sources (two laptop 19v 4a ac adaptors)
Than i will check if the signal to the igbts are i expect them to be and than i´m ready. its 1 o-clok... the all thing is very impressive. i´m going to figure out a way to put the images from my phone to this computer...
I would like to make a live meeting on skype tomorow after 16:00  if any of you are interested send me a pm with your skype name and get online tomorow, do any of you know if is possible to mke video meeting with more than 2 computers tell me how please.
BEst Regards to All
Re: ALTERNATOR
« Reply #113 on: September 09, 2010, 19:38:31 pm »
~hELLO
I GUESS I DISCOVERED THE FUNCTION OF THE MOVABLE WIPER COIL
IT IS THERE TO ACT AS A PATH FOR THE IONS TO DISCHARGE THEIR ENERGY BY INDUCING FURTHER VOLTAGE IN THE OTHER RESONANT CHARGING CHOKE. hOWVER ITS IMPEDANCE SHOULD BE MAYBE MORE THAN 10 TIMES SMALLER THAN THAT OF THE WATER OTHER WISE CURRENT WILL LIKE TO DISCHARGE INSIDE THE WATER.. .
pICTURE THIS
yOU HAVE 1000 VOLTS THRU WATER
yOU DISCHARGE THIS THRU A COIL WITH 10 OHMS IMPEDANCE, YOU WILL GET 100 AMPS;
iF THIS 100 AMPS BY TRANSFORMER ACTION INDUCE A VOLTAGE IN THE OTHER COIL DURING PULSING OPERATION WITCH IS 10 TIMES BIGGER YOU WILL HAVE 10000 VOLTS BEING INDUCED AT 10 AMPS  AND SO ON
sO IF THE CONTAMINANTS CHANGE THE FREQUENCY WILL ALSO CHANGE BECAUSE WILL CHANGE THE SPEED AND THE AMOUNT OF IONS THAT WILL BE DISCHARGED IN RELATION TO THE CHARGE WITCH IS GETING IN THE CAPACITOR FOR EACH CYCLE.
baSICALY YOU NEED TO HAVE TWO COILS WITH RIGHT PROPORTION AND COUPLING TO REACH THE WATER IONIC RESONACE..
i GUESS THE FREQUENCY WILL BE DICTATED BY THE MUTUAL INDUCTANCE. . ALLONG WITH THE DIELECTRIC OF WATER AND ITS CONTAMINANTS;;;
Re: ALTERNATOR
« Reply #114 on: September 09, 2010, 22:14:50 pm »
Hmmm,
Could there be a test setup proving the theory, Fabio?
If you could prove just a small piece, then we could go from there.. ???
Re: ALTERNATOR
« Reply #115 on: September 10, 2010, 03:55:13 am »
Really,  you are talking about 100Kwatts being recirculated?
Are you high?
I will admit that I have not shown anything that amounts to a hill of beans,  but this is wacked out B.S.   You have not proved anything either except that you like to post a lot and  ask for money to support your whacked out theories.  I have an open mind not constrained to conventional theories and teachings, but...
I've been working silently and spending A lot of money SUPPLEMENTING MY OWN IDEAS AND NOT ASKING FOR DONATIONS TO SUPPORT ME, MY FAMILY, AND RESEARCH TO DO GOOD FOR THE BETTERMENT OF ALL MANKIND!!!
To everyone reading this, I'm sorry for adding more clutter to this thread, but I'm sick of reading SO MUCH B.S. that is either from idiots or deliberate distractors. And I'm not just talking about this website.
One more thing.  Sebosfao, are you  Dankie's long lost brother?
Again, sorry everyone, I'm not exactly sure what lit my fuse(probably Tequila hehehe), but I am tired of trying to read about progress and broaden my thinking, only to waste my time on stupid ideas.
There is no wiper on the coil!!!
His drawings are only representations, not real schematics!!!
AND.... the wiper only represents that the circuit is tunable.
How many tunable inductors have you seen that can handle 100Kilowatts?  I mean really W.T.F. ???
The real tuning is through the pulse width,frequency and gate time(number of pulses) of the primary of the transformer vs the value of the bifilar charging chokes.
Uhh, sorry, but I feel better now.
Mike
Edit:  I man'd up, I'm not sorry for posting this!!!
~hELLO
pICTURE THIS
THIS 100 AMPS BY TRANSFORMER ACTION INDUCE A VOLTAGE IN THE OTHER COIL DURING PULiF SING OPERATION WITCH IS 10 TIMES BIGGER YOU WILL HAVE 10000 VOLTS BEING INDUCED AT 10 AMPS  AND SO ON
« Last Edit: September 10, 2010, 11:34:45 am by Steve »
Re: ALTERNATOR
« Reply #116 on: September 10, 2010, 06:10:54 am »
Hello steve
I´m working on it to prove the concept, this weekend i can have more done. Everything is up runing, osciloscope the circuits the igbs... And i noted a strange effect witch a certain configuration... Outlawstc have see it on skype it kind of created a ring and the sound of the alternator get really strange and the wire sharing the ground of the two igbt circuits got really hot anything else did... // I´m trying to find the right configuration.. . I´m really sure about what i´m talking about.
@ mike i hope you feel better
Wake up for life;
i´m giving to you knowledge
you should be at least respectfull
BEst Regards
Re: ALTERNATOR
« Reply #117 on: September 10, 2010, 09:20:37 am »
there isnt much of a observation over skype my friend.. im not sure what you have going on over there completely just know ur using some igbt's and pulsing a alternator..  sure it made strange noise but this doesnt mean your on the right path.. yea i heard a noise but i didnt see any gas production.. so dont throw me in like you have accomplished somthing and i can back you up... right now seb you have what we call a hypothesis.. this means
a proposition, or set of propositions, set forth as an explanation for the occurrence of some specified group of phenomena, either asserted merely as a provisional conjecture to guide investigation (working hypothesis)  or accepted as highly probable in the light of established facts. keep observing and with experimentation you may be able to propose a theory..
seb you wanna prove yourself make clear drawings and clearly describe your ideas and dont go around saying you have somthing when you havent even got results yet.. funny noises dont count.
Re: ALTERNATOR
« Reply #118 on: September 10, 2010, 11:55:43 am »
People,
Like you all, i had some bad days too. Working day and night at this water as fuel project costs much in money and mind. Doing everything like many claim and then come to conclusions that it doesnt work is frustrating. Doing 100 tests and just see 100 failures is not doing good as well.... >:(
But please keep respect for eachother. Thats really all i want here.
We all read Sebosfato's theory's. We all know by now that he try's to think outside the box.
Why? Because we tried everything thats inside the box. Try to see it as inspiration and not as BS. Who knows. He might tricker your mind and you might link something towards your own experiments.
Mike,
We would like so see more of your experiments, if possible. I seen you around on multiple forums for years. If you shared your knowledge here, we all could use that.
Like i do, for example. Willing to share it all. That way your goals can be reached quicker.
Alone it is not possible. I took some words out your post because i tought they where too much. I left the message in tact. (btw, i like whisky..)
To you all:
I know that many think that they are loonly testers and that too many are lurking.
I have that feeling a lot. I seen so many people reading this forum and just so little amount of info is coming back. Please share all your not working experiments with us. At least it can save others money. But you may share the working ones as well... ;) ;)
Administrator
Re: ALTERNATOR
« Reply #119 on: September 10, 2010, 20:36:42 pm »
Hello guys
i did more tests today and i found again that strange effect.
I developed a schematic for the electron extraction that could work for the vic setup in witch the primary resonates with the water for the discharge cycle and the secondary charge the capacitor..
Basically i think that the secondary must have a diode and in series a coil with fields aiding, this will form an electron pump or a very high impedance and unipolar output, while for the next cycle when the pulse on the primary is reversed the coil is connected to the cell thru one igbt, (having alredy the positive from the battery connected to one of the sides of the cell) thus discharging the ion and restricting amps as the transformer will be full of energy from the discharge....  The coil alredy energyzed but with reversed polariti will than discharge the ions... The vic configuration (secondary with coil in series with a diode there between) with the primary being pulsed but than discharged inside the water instead of reversing the pulse..
Do you understand what i mean?
Now i´m trying to figure a way to do this with the alternator but i´m starting to think that is more complicated...
I need to make many many tests...
Oh mike, about the variable inductor, you could be right or wrong, however there are no limits for an inductor...
one thing that crossed my mind is that it could be there to cancel out the other inductor action as a mean for fine tuning the impedance of the secondary...
who knows..
Steve i´m going to check again your schematic...
