Author Topic: Ultrasonic Nebulizer Array 3000mL per hour Cold Fog Generator WATER BURNS  (Read 154443 times)
It has become more then clear to me what it is we're after is a ultrasonic Brown's Gas Generator. It might be easier to learn of electroceramics and redesign Stanleys system. The ceramic material used will probably be what he coated the tubes with.
Even if Stan didn't do it' s great that over all these years you have stuck with the ultrasonics , I remember you starting out with it way back when.Ive been working 80-90 hrs a week for a while ... finally gonna work a lil more on my TSG circuit tonight  :)
  • let the voltage do the work
I've heard that meyer did use ultrasonics ..
I think the relationship between Stan's work and Ultrasonics is one that is hard to see. I've had a certain gut feeling you might call it that I might one day share with everyone. But for now will stick to the facts of information I can pair up to prove that Stan's System was indeed ultrasonic device. I might start another thread with only the info that pairs Stan's system with ultrasonics or I can just repost it in this thread. If I remember correctly the beginning of this thread starts off with this info. I'm not here to argue I just have an ability to line up info kinda like putting together a jigsaw puzzle. If you would like I can share as much as possible to show the alignment of the 2 process so you may also see the relation I'm making with ultrasonics and Stan's process. Mean time check out these electroceramics and their compositions and let me know what you think of them. Specs say they have high ionic conductivity and ionization energy.
Scandia Stabilized Zirconium Oxide Sc-ZrO2
http://www.americanelements.com/scz.html
Zirconium Oxide Particles High Purity ZrO2 Particles
http://www.americanelements.com/zirconium-oxide-particles.html
PZT (Lead Zirconate Titanate) Pb [ZrxTi1-x] O3 (0≤x≤1)
http://www.americanelements.com/pbzrtio.html
I'm trying to change the ionic bond from  2H−+ O ++ to the isomer  2H++ O− −
 I'm open to any other compounds you might suggest as well.
ok I'll admit I was just trying to hit the hundred mark quicker. I'm honestly trying to keep the amount of times posted small this tells me how realative the info is by how many people have viewed it. I'd rather have a lower number of good post then a bunch like this one but hey it's my 100th and only one of it's nature if I remember correctly.. So 180 views to every post isn't a bad score at all excuse me all for the last 2 screw ball post. Well the last was actually to remind everyone about the ionic configuration I'm looking to achieve. But we can call this the 100th celebratory party post....
 :D WooHoo... I'm a full member now... :)
Just a question for everyone. This is a little off my current topic but relative none the less.
Check out this link here and tell me if you think it resemblances to Stan's work by any chance.
I've met this person once before and it has kinda sat on my brain and bothered me for some time now.
Just asking the thoughts of the collective whole again. At the same time when asking questions of him it always seemed to be the answer in which was 180degrees of the right answer.
http://www.rexresearch.com/rosocha/rosocha.htm
« Last Edit: June 21, 2013, 13:26:47 pm by Steve »
what's my posting status? too busy with exams this time of the year will try to make iron man suit for christmas later
