Author Topic: Ultrasonic Nebulizer Array 3000mL per hour Cold Fog Generator WATER BURNS  (Read 154358 times)
0 Members and 26 Guests are viewing this topic.
« Reply #112 on: December 16, 2011, 16:18:30 pm »
Thank you Dave for the suggestion and yes I thought about infrared but could find any high power modules. I recently found 5watt infrared LEDS at 850nm and 940nm spectrum. I'm waiting for them from China. I'll keep everyone posted.
Here is the ebay link to a supplier.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180774998032
« Reply #113 on: December 24, 2011, 16:50:45 pm »
Pic show water fog mist is equal to wavelength of fog droplet. www.scaleofuniverse.com
 Particle collision is helping free electrons to outer ring so that they may be consumed in the electron extraction circuit. In this pic you will notice the water mist droplet to be the same size as the wavelength as the infrared spectrum. So I imagine a very high pulse rep along with high intensity bombardment of the water fog with have some excellent outcomes with assisting in the destabilization of the water molecule.
« Reply #114 on: November 25, 2012, 20:15:03 pm »
 The misting Principle of Water
Install the Piezoelectric ceramics disc (also called misting disc) in the bottom of a container with water and add the driving voltage generated by one driving control circuit with the same resonant frequency. Then the Piezoelectric ceramics disc will generate oscillation energy. The oscillation energy will spread toward the direction that perpendicular to the surface of oscillation. With appropriate water depth, the water surface of the energy spreading shaft will hunch a column. The front of the column intensively generates a lot of tiny tension wave, greatly reducing the surface tension of the hunched water. The water surface is divided into many tiny areas by the wavelength of the tension wave and every area become many independent micro-particles seeming separate spreading in the air and forming mist. This is the water misting principle utilizing Piezoelectric ceramics disc.
« Reply #115 on: December 01, 2012, 07:23:07 am »
Updated design of fogger unit.
HV neg ion gen
IR and red spectrum light in tube.
« Reply #116 on: December 01, 2012, 11:17:10 am »
Nice to see you keep on working on this thems FI!
Did you see any positive or negative results yet?
« Reply #117 on: December 01, 2012, 19:25:40 pm »
Very positive using potassium bicarbonate. But the fogger burnt up. I later found these notes on fogger.
The transducers should be used in drinking water or liquids similar to water. When such liquids have an acidity of less than pH5 or an alkalinity of greater than pH8,the transducers may deteriorate or be permanently damaged. Therefore, the transducers cannot be used with a liquid that is excessively alkaline (pH-8) or acidic (pH-5).
This is the next step is to make sure I have this part covered..
quantum of electromagnetic energy carried in a small amount and moving with the
speed of light, as so illustrated in Figure (5-11). Optical Photon having energies corresponding to
wavelengths between 120 and 1800 nanometres ... thus, propagating sun's light or its direct rays (539a
xxx 539n) of Figure (5-6).
And I need another fogger which I don't have cash for at the moment.
« Reply #118 on: December 02, 2012, 10:06:54 am »
Please tell us a bit more. What was that positive sign you seen?
« Reply #119 on: December 04, 2012, 03:10:21 am »
A whole lot more torque was produced. I got into throttle turning right on dry pavement slid 90degrees of center and tires continued to spin until I was straighten out I could've kept tires spinning awhile longer but the transmission made a slight churn noise from the tranny when I let off the gas. The engine was running extremely smooth. through out power range.. Hope to get a new foggert so I may resume testing soon...
