Author Topic: Ultrasonic Nebulizer Array 3000mL per hour Cold Fog Generator WATER BURNS  (Read 154638 times)
« Reply #8 on: November 14, 2009, 23:19:23 pm »
Just as cavitation bubbles form on a fast-spinning boat propeller, they may also form on the tails and fins of aquatic animals. The effects of cavitation are especially important near the surface of the ocean, where the ambient water pressure is relatively low and cavitation is more likely to occur.
For powerful swimming animals like dolphins and tuna, cavitation may be detrimental, because it limits their maximum swimming speed.[5] Even if they have the power to swim faster, dolphins may have to restrict their speed because collapsing cavitation bubbles on their tail are too painful. Cavitation also slows tuna, but for a different reason. Unlike dolphins, these fish do not feel the painful bubbles, because they have bony fins without nerve endings. Nevertheless, they cannot swim faster because the cavitation bubbles create an air film around their fins that limits their speed. Lesions have been found on tuna that are consistent with cavitation damage.
Cavitation is not always a limitation for sea life; some animals have found ways to use it to their advantage when hunting prey. The pistol shrimp snaps a specialized claw to create cavitation, which can kill small fish. The mantis shrimp (of the smasher variety) uses cavitation as well in order to stun, smash open, or kill the shellfish that it feasts upon.
« Reply #9 on: November 14, 2009, 23:53:22 pm »
picture of cavitation damage:
(http://www.originalpropshop.com.au/Images/800px-Cavitation_Propeller_Damage.jpg)
This picture below, is completely underwater! the bubbles you see are boiling water caused by low pressure, cavitation!
(http://i201.photobucket.com/albums/aa105/kenuwf/cavitation.jpg)
another one, pretty cool!
(http://www.rcboataholic.com/images/props/cavitation.jpg)
« Reply #10 on: November 15, 2009, 00:58:30 am »
There's a pic of something I use to seeing jet ski impeller burnt by cavitation.
« Reply #11 on: November 17, 2009, 09:57:50 am »
Dissociation of the water molecule by way of voltage stimulation is
herein called "'The Electrical Polarization Process".
,Subjecting or exposing the water molecule to even higher voltage
levels causes the liberated atoms to go into a "state" of gas
ionization. Each liberated atom taking-on its own "net" electrical
charge. The ionized atoms along with free floating negative charged
electrons are, now, deflected (pulsing electrical voltage fields of
opposite polarity) through the Electrical Polarization
Process ...imparting or superimposing a second physical-force
(particle-impact) unto the electrically charged water bath.
Oscillation (back and forth movement) of electrically charged
particles by way of voltage deflection is hereinafter
called "Resonant Action", as illustrated in Figure (1-10).
Attenuating and adjusting the "pulse-voltage-amplitude" with respect
to the "pulse voltage frequency", now, produces hydrogen gas on
demand while restricting amp flow.
Stanley A. Meyer
« Reply #12 on: November 18, 2009, 08:30:04 am »
Cavitation is a very interresting phenomenon .
The steam resonator was interresteing indeed , perhaps the real truth lies somewhere in the middle of the VIC and steam resonator , something is missing thats for sure  . Physical vibration of elements/echoing of the sound/timed voltage spikes  .
The only thing I wanna know is what link does element lenght and water have , what is that dam water resonance , or is there .
Somebody throw out a number from the bible  , the truth must be somewhere , perhaps it is a mutiple of the water molecule wavelenght or some phi thing ...
Perhaps it is an X value and is just meant to be tuned around that element , no special relationship involved .
« Last Edit: November 18, 2009, 08:45:25 am by Dankie »
« Reply #13 on: November 18, 2009, 09:48:54 am »
Dankie
EXACTLY EACH WATER CELL RESONATES AT DIFFERENT FREQ.
THEY DIDN'T HAVE ULTRASONIC TRANSDUCERS WHEN STAN WAS DOING THIS RESEARCH. He made his own for the job.
