Author Topic: Ultrasonic Nebulizer Array 3000mL per hour Cold Fog Generator WATER BURNS  (Read 154661 times)
  • let the voltage do the work
SUPER SECRET REVEALED
« Reply #128 on: May 28, 2013, 20:43:08 pm »
since you have the equipment try this : mix two electromagnetic wave frequencies one multiplied or divided by the golden ratio number..
here is someone who figured out what I say : http://www.energeticforum.com/renewable-energy/13483-log-periodic-golden-ratio-coaxial-waveguide.html
I dont know if it works or not .. you try and tell us.
Thank you, Geon
I picked that unit up off eBay they were such a good deal $43 I took 2. If you look you might be able to get one yourself or just wait till I can give you a better solution provided things go as planned.
  I will try this as soon as I can get some materials. I imagine this is for the the injector and looks to be correct in theory. I'm not sure the material is the correct selection. But the principle is sound. I'm hoping if all goes well to build many different devices starting with this one project. I assume this is Aron's device or is it Gron's?
Or is it Geons?  ;)?
Way to go FI3... I hope you do well enough to keep on going...  8)
http://www.kickstarter.com/projects/172591194/2087101639?token=ab8852f5
This btw is how I found Kickstarter I don't know who made it but I figured this is what I've been waiting for so I'm going for it.
http://m.youtube.com/watch?feature=plcp&v=jICNLy_uyCg
Impressive video FI3!
Way to go!
something to remember if you try this you need to go up to 4-5 digit accuracy or else it won't work
Way to go!
Thank you guys...
I have located more accurate answers and even equations to help obtain the correct values on the parts your going to need will post as in a moment hopefully. I'm trying to narrow down info to provide exact answers. I think it's hard for others to see the exact answers by seeing the relative info within a large amount of info. In which I located the answers in if it's not shown to them  by me. I have to remember I have a gift in which allows me to see this  way... So I need to work on showing the exact alignment of info in which the 2 separate pieces fit together...
Ok guys I think I might need your help.. But I have a huge key piece of info to share I found. This info contains all equations and explanations of the functions of different ceramic materials. I'm quite sure from the results I have of my cell which is not designed to spec yet. (Well, it is if you only look at one referencing sorce for the answer.)
But if you combine all the the info I'm lacking a resisitive material that will remove the heat and slow the conductivity of the components. The diode mainly at this time but also the water. I will shot a vid or 2 so as to get the effects occuring with the ultrasonic power supply.
Pure water gets hot like a microwave but if you add electrolyte the heating of the water is minimal. I believe it is because the electrons become locked up and no longer vibrate at set frequency but I might be wrong. I have seen this before when I tried to pre-heat water with electrolyte in the microwave I found it to be rather strange then and still do think it's a little funny of it. But it is how it is. If built right this will work. Finding a design engineer with company that is willing to help I think is going to be a problem.  I'm currently working on trying to obtain assistance from Ceradyne, Inc. Which is a American based company. But if this is not sucessful I will try Morgan Advanced Materials out of London.
http://www.ceradyne.com/
http://www.morganadvancedmaterials.com/products/engineered-ceramics/
I'm shooting a vid of cell output for everyone to see and no it won't be measured. I'm not building a group cell design til I have the cell done. I'll show you temps of components though and ignition of course. My favorite part is combustion. Which if you haven't noticed changes per your electrolyte. The cell in this vid will have potassium bicarbonate KHCO3 and iodine I.
Below is also a pdf with need equations for the cell along with a scren shot highlighting the tubular design to be lined up with Puharichs patent info.
