Author Topic: NEW RESONANCE CIRCUIT  (Read 11216 times)
« on: August 31, 2008, 21:29:14 pm »
Hi,
If resonance was involved in the Stan Meyer setups, it should have looked like this.
(Thanks to Richy Burnett, http://www.richieburnett.co.uk/dcreschg.html )
The tank circuit is charging the capacitor to twice the voltage as the powersupply is providing.
Then you close the circuit to discharge the cap into the wfc.
Maybe the circuit needs the be cut off  from the powersupply when the switch is on to the WFC......any thought from you outhere?
Hopes this helps
steve
hydropower
Re: NEW RESONANCE CIRCUIT
« Reply #1 on: August 31, 2008, 21:33:49 pm »
Damn...we should have known that one tonight if i hadnt burnt a transistor    :D
Hydropower
« Reply #2 on: August 31, 2008, 21:55:01 pm »
Hi,
The idea on this circuit is: AMPS
Almost no amps for charging, but lots of amps from DISCHARGING
Example:
I charge a cap to 600V. (I use a 300V powersupply and the circuit uses resonance to get it up to 600V)
The resistance of the WFC tubecell of my has a resistance of less then 1 ohm.....
For calculation, lets take 1 ohm as a number.
When i discharge a 600V cap with a 1 ohm resistor, how much amps do you think will flow?
Yes, 600 amps for a brief moment.....
Does that make you all think?
hydropower
« Reply #3 on: August 31, 2008, 23:11:29 pm »
It is very interesting...thank you stevie1001
Hydropower
Fiditti
« Reply #4 on: August 31, 2008, 23:16:45 pm »
Thanks Stevie,
Very exciting circuit indeed.  Those are some high amps.  The potential for very high gas output is possible with this setup.
« Reply #5 on: September 01, 2008, 13:58:26 pm »
After doing more mind breaking thinking.........
I added a resistor , so the time is longer for the discharge. So less amps are blown at once, and  the discharge duration is longer.
This can be needed if you see and experience a deadshort on yr tubes or plates.
The last schematic is showing a new place for the wfc. In that case, you can do the switching on 1 place.
Hopes this helps.
Fiditti
« Reply #6 on: September 01, 2008, 14:15:48 pm »
Stevie,
What program are you using for your circit diagram pic?  I save the pics to my computer, and then I can't pull them up later.  Thanks.
« Reply #7 on: September 01, 2008, 14:19:29 pm »
Stevie,
My last adjustment are done in MS paint...........
Normally i draw with MS Visio.
steve
