Author Topic: NEW RESONANCE CIRCUIT  (Read 11218 times)
HydroRamPac
Re: NEW RESONANCE CIRCUIT
« Reply #16 on: September 03, 2008, 04:50:32 am »
Hi,
Nice discussion, but how do you get a 1000v across a wfc?
The wfc will deadshort.
H2Opower, you write that you do not short the wfc if the water is moving?
H2Opower, can you show us some experiments? Like vids of yr work?
I would love to see yr HV setup working.
What my schematics shows is a way of getting 1000v discharged into a wfc and if you do that on a specific speed,
you will get lots of amps in the water. Provided by the real tank capacitor.
Use OHM's Law:
I=E/R
You can use a dielectric compound (ie Super Corona Dope 4100 ohms baked) or add a resistor or pot (ie 1000 - 4000 ohms) on to the ground side of the circuit.
How much current or how little do you want?
I= 1000v / 4100 ohms
I= .2439 amps
Hopefully this helps.
Your Brother in Research,
Robert
Fiditti
« Reply #17 on: September 03, 2008, 23:48:00 pm »
H2OPower,
Thanks for the clarification.
« Reply #18 on: September 04, 2008, 10:16:46 am »
Is this what are you describing h20 ?
Do you think that an electron extraction circuit should be added to consume the electron buildup in the water ?
hmask
Fiditti
« Reply #19 on: September 04, 2008, 13:54:34 pm »
Very nice drawing Hmask.
Fiditti
« Reply #20 on: September 05, 2008, 03:07:37 am »
Thanks H2OPower!!
« Reply #21 on: September 05, 2008, 15:49:09 pm »
H20power, can you please elaborate
« Reply #22 on: September 07, 2008, 11:41:01 am »
Sorry for not catching that before h20
Fiditti
« Reply #23 on: September 07, 2008, 14:07:02 pm »
hydrogenmask,
You might want to do a search for h2opower.  He has a lot of posts in many different places.  There is a lot of information in his posts.  I'm going to try and organize his posts and some others in my computer so that I have easier access to everything and then I can also organize it.  It's been hectic, so this may be a ways out.
