Author Topic: Stevie1001 JLN replication  (Read 12324 times)
« on: June 29, 2008, 10:07:52 am »
Hi,
I have build the circuit and i have the trafo and HV probe for my scope.
Still to build is the bifcoil accoording to the JL specs.
Also need destilled water... ;D ;D
Br
hydro
Re: Stevie1001 JLN replication
« Reply #1 on: June 29, 2008, 10:15:35 am »
while your at it,, post them transformer primary and secondary windings and wire gauge so we want be left in the dark..
« Reply #2 on: June 29, 2008, 10:22:33 am »
Well,
Thats what i will do after i made a SUCCESFULL replication....
But to help you out, the toroid trafo is a 12V 4amp in and 230V out type of Velleman
« Reply #3 on: June 29, 2008, 10:37:15 am »
Looks good Stevie. Hope to see resonance.
Where can I buy a non super expensive HV probe. I found this one on ebay:
http://cgi.ebay.com/One-new-100MHZ-Oscilloscope-clip-probe-x100-up-to-4KV_W0QQitemZ280082119735QQcmdZViewItem?_trksid=p3286.m20.l1116
Is 4Kv max good for this? what do you suggest ?
Hmask
« Reply #4 on: June 29, 2008, 11:01:02 am »
Hmask
Hmask,
I have the same hopes.! ;)
My probe is:
Tektronix P6015A
High Voltage Oscilloscope Probe, 20kV, 75MHz, X1000, 10 ft. long Cable
New price: $1,450.00
http://www.testpath.com/Items/High-Voltage-Oscilloscope-Probe-20kV-75MHz-X1000-10-ft-long-Cable-117-551.htm
And NO. I didnt pay that for it....i bought it on a local ebay site in my country for 150 US dollars.
I think that 4KV is not enough.....sorry. This because i think that we will start here with 2KV and probably end up much higher, as soon as we understand it all. Stan talked about  20KV......
« Reply #5 on: July 02, 2008, 22:00:57 pm »
Ok,
Some technotes from me.
transformer toroid 12v / 230V
Capacitance of SS tube cell: 1nF19
Inductance of Bifcoil: 120uH each coil so totall inductance should be 240uH
resistance: not measurable
Calculated resonance: around 300khz  ?
Diode: BY329 (1200V)  (fast switching)
My circuit doesnt run on 300khz so i think i have to get me a bigger and longer SS tube for more capacitance.....
No results, yet.
« Reply #6 on: July 17, 2008, 08:45:40 am »
where did you buy your transformer from?=
« Reply #7 on: July 17, 2008, 11:24:10 am »
local store!
