Author Topic: My new approach  (Read 21944 times)
Quick Update
« Reply #96 on: April 09, 2023, 13:57:26 pm »
The cell is almost ready, unfortunately only one member in the team is going to see it…
Funny but not so much
I designed a special secret stuf that goes in my cell using my 3d printer and kind of refurbished the cell you see in my YouTube video giving it a total new shape and size of electrodes all build in with the special secret ingredient
Also it will be fit in this secret cell that is what I’m going to show in the videos from now… it’s made of acrylic and it will be painted black to get rid of curiosity so people can see the so called unipolar stepcharging effect and get amazed with only that
Hope it inspire people willing to join this small team… to much knowledge for few people sharing
I show you the last pic of the electrode before get back into the cell…
Re: My new approach
« Reply #97 on: April 09, 2023, 21:05:48 pm »
The outside of this electrode will be glued to the acrílic tube so it won’t be able to get out anymore from there
I’m using the inner electrode unmodified in lenght but having good electrical connection on both sides… and so all is going to be sealed in polyester tape just to reduce the length of the electrode exposed to water
The 3d printer is making some pieces to fix the electrode in the cell centered while allowing a great deal of hydrodynamic even with the wires coming out of it
I may coat that ear in the electrode too… such that only the exposed parts will be in contact with water and the rest of the electrical connections above 5kv isolation!  That will avoid any leakage outside of the region of interest…
Pendulum overunity
« Reply #98 on: April 11, 2023, 13:37:36 pm »
Re: My new approach
« Reply #99 on: April 12, 2023, 23:10:02 pm »
My acrylic tube is somewhat thin and I believe it may explode if the cell works…
Water is very little compressible so any water pressure will be transferred thru the wall
To achieve the level of power required I probably will have to use a stainless steel cavity
This project may started to get somewhat dangerous
Perhaps adding a steel holder from outside the pressure can be contained..
Bitten pizza shape will change the way we look at a water capacitor write that on a paper
Longitudinal linear excitation would mean:
For higher length a higher current input output power
For a wider gap a higher voltage output input higher
I’m studying the geometries possible to see what’s the best way of exciting the cavity into resonance and generate the most voltage output from it…
Static and dynamic fields can be used in combination to get the most of it
But basically focus on the high amps diode it tells there’s somewhere high amps flowing
« Last Edit: April 13, 2023, 03:03:35 am by sebosfato »
What is the meaning of this image for you?
« Reply #100 on: April 13, 2023, 03:20:46 am »
This is very meaningful now for the tests I’m doing..
Look at the arrow
This tell that energy is flowing from a dimension into others according to him and that when when create this aperture and water is in between this energy flow or maybe perpendicular to it than simply the covalent bonds switches off
What mean energy flowing from one dimension to others in an electronic circuit for you?
Could it be energy flowing from thru one component or other?
What would be an isolated universe in terms of electronic circuit?
What if he just shoved the secret in your face?
« Reply #101 on: April 13, 2023, 10:57:57 am »
Read this once again appendix B in attachment…
Re: My new approach
« Reply #102 on: April 13, 2023, 14:47:08 pm »
RE: Glossary of Application Notes Appendix B
Note 1) The Electron Inhibiting Effect (631) of Figure (7-6) to cause "Electron Clustering"
(Grouping/collecting negative charged particles at a given point) (700) of Figure (7-9) to produce
"Negative Voltage Potential” ( B- ) at one side of Water Gap (Cp) of Figure (7-8) is accomplished by
low electrical power input (Tab 38) when Choke-Coil (62) of Figure (7-1) magnetic field (FL2) (690)
of Figure (7-8) during pulse on-time (49) impede "Electron-Flow" since electron mass is composed of
electromagnetic matter which interacts with magnetic field strength (FL2). Capacitance Charging
Effect (628) prevents amp influxing away from Water Gap (Cp) in a similar manner .... producing
"Electrical Stress" (SS' - RR') (B+/B-) across Water Gap (Cp) since both Choke-Coils (56/62) conducts
voltage potential (Negative or Positive) during pulsing operations.
Note 2) In determining volumetric sizing of the atom, Neutrons Clustering only enlarges the nucleus
surface area since the additive Neutron (s) exhibits no electrical charge to deflect or change the orbital
spin-velocity of the atom electrons.
Note 3) Universal Energy (9) of Figure (5-10) being a continuous energy potential (source) (C2)
coming into our space continuum and creating and sustaining/maintaining our expanding universe, as
so extrapolated via mass equation E=-MC2. Whereby, Universal Energy (C2) having native intelligence
to create mass (M) (to cause electromagnetic wave-Vectoring - photon structuring _ electron to proton
grouping to form atoms - molecular arrangements to bring-on chemical processes to sustain life) which,
in tums, emits radiant energy (E) under different stimuli conditions ... example, particle oscillation as a
energy generator by way of “Electrical Stress".
This needs to be checked
Highlights
« Reply #103 on: April 14, 2023, 04:29:03 am »
Highlights:
Magnetic field fl2
Under different stimuli
Amp influxing away from water gap
Producing
Electron clustering
Meyer made everyone think he was talking about something happening at the coil..
Or may the instinct of self destroy lead most to that way
While obviously he at the same time talk all the theory shoving in everyone’s faces
Is very interesting looking at this after some years of cleaning mind because I became depolarized and this way was clearer where to look at…
I’m had an accident in this carnival that I hurt my head and now I’m starting to forget some stuff… luckily hope there still time to finish the project before I become a blank page.
That made me an urgency to get this done as soon as possible and here I’m.
Working every day 24hs to get things done the best I can
« Last Edit: April 14, 2023, 06:32:05 am by sebosfato »
