Author Topic: My new approach  (Read 21771 times)
Re: My new approach
« Reply #176 on: June 18, 2023, 02:55:35 am »
Sadly, most of everything I had built, or amassed was stolen from me in 2010...I was not in a place then to pursue getting it back, or suing for damages.
I am at a point now, that I have rebuilt my assets to a level that I can resume.
I will definitely check your channel, and glad to hear it, I need to get another old school ignition coil (the trick is capacitive discharge through a high inductance coil, and modern CDI coils have low inductance), or see if it possible with what I have now, to make some videos. I recently just decided to resume open sourcing it, I'm in the middle of organizing my tool shed and other storage to get all my stuff together, so it's not going to be at such a speed as I once shared lol...but I still have my original youtube channel, and I plan to use it...Zer0pointunlimited...Glad to see you here.
I won't hijack your thread, I will start a new one very soon.
Re: My new approach
« Reply #177 on: June 19, 2023, 07:27:15 am »
Today I finally applied the resin to the cell
I took 20 g of the encapsulement resin that was black and added 15g of tinanium dioxide powder and 2,4 g of the hardeners
It came out ligh grey color at adequate density so it could be applied and stay in place the resin was already very heavily loaded but was not solid first I added the hardener to mix well than the titanium powder
I’m happy with the results it hardened well and now I just need to glue into the pvc pipe so  I can start the first tests…
Having multiple pipes like this would be possible to add them in series I think maybe 8 may be enough to run a small car like a buggy
The nice thing is that is scalable in that way withou requiring other components
The more cels in series the higher will be the efficiency since the diode voltage drop become less significant
Of course each pipe will require a coil and or core and so this losses are unavoidably raise proportional to the system size
Perhaps adding more capacitors will also be needed and diodes in parallel or even some better active switching in parallel with diodes using mosfets since it will become only dependent on resistance for the voltage drop so adding enough mosfets this can be very low
Re: My new approach
« Reply #178 on: June 19, 2023, 09:13:33 am »
Just expounding on what Steve told you about someone close to Stan saying he was dumping a capacitor into the transformer...and then about longitudinal waves.
A capacitor discharged into an inductor will immediately send the voltage (this IS the longitudinal wave component), the current flow will lag (the transverse wave component), the current is out of phase with voltage lagging 90deg.
As the current starts to flow, it creates a counter flow in direct opposition (self-inductance), which also creates a counter EMF that opposes the growing forward EMF (both of which "choke" current flow)...Any mutual inductance does the same thing, magnetically coupled (secondary) windings create a growing counter induced voltage/current and emf. This is only the case as the current is changing. Straight DC will not have this "choking" inductance...also, saturated cores will have under-dampening, with similar low inductance results.
Lastly, the key thing to keep in mind... Delta Work/Delta Time= Power....work=distributing current into coil to make EMF...self-inductance=opposition, or delay in the current distributing across a coil. Therefore, it increases Delta Time, and lowers power...same thing happens as the field collapses when current stops.
That being said, what if we could ground-out or "short-circuit" just the self-induced or mutually
-induced counter current that is lengthening the change in time? What would that do to the counter EMF? (Hint a low resistance load on the secondary of a tansformer creates a magnetic "sink" and lowers the primary coil's impedance which draws more current, which really means current travels faster).  Lastly, if in a dead short, wouldn't that mean the counter current was flowing, and as the inducing current rises, wouldn't the counter current be accelerating? (Again, think back to low resistance load on tranformer secondary). If the short circuit counter flow is accelerating, what's happening to the magnetic "sink"?Then what would happen if that dead short became an open circuit the moment current stopped flowing from the forward inducing capacitor/pulse and the EMF starts collapsing(flyback)?... 🤔💡
« Last Edit: June 19, 2023, 11:30:24 am by Radiant_1 »
Re: My new approach
« Reply #179 on: June 19, 2023, 09:25:14 am »
If mutual and self-inductance is in opposition to forward flow, then what happens when we allow these counter currents to flow outside of the inductor?? Would it not release their opposition inside the inductor, and would they not create their own mutual or self-induction starting from within the inductor? What is the opposite of an opposition??? 😎🤓
Re: My new approach
« Reply #180 on: June 19, 2023, 11:26:12 am »
Then what if there was a "pumping" diode before the inductor in line with forward current flow and the capacitor dump or pulse was off/empty before the current got through the inductor?? 🤔
Current duplication/amplification, followed by a nice big boost in voltage potential via flyback, and disconnected faster than the current can close the loop making an increased load on primary.
Just to be clear...initial VIC stage utilizes time compression positive feedback loop (Diode shorting the mutually induced (in opposition) forward pulse of the secondary), the secondary circuit's charging chokes take advantage of self/mutual inductance lag, instead of an accelerating positive feedback loop. Having a single pumping diode to completely halt self/mutual inductance flow (having reverse polarity) making it maximum possible opposition in the inductor, as no diode would allow the induced opposing current to flow towards and into the WFC in reverse, creating it's own self-induced counter flow that would work with forward current pulling it through faster. This gives absolute minimum forward current flow, or in other words, "amp restriction", until the forward pulse ends. As the inducing forward current shuts down, the voltage distributed across the inductor from the initial forward current, reverses when the capacitor/pulse is off/empty, (see RLC circuits). Both currents are now in phase having the same polarity, and become one larger current, the EMF collapses in a much shorter time (see..."flyback", and a smaller delta time=more power=higher voltage) and voltage inverts back to the original polarity, inline with the pumping diode polarity at a significantly higher voltage, current close to doubles, and voltage more than doubles...much more energy moves forward into the WFC....🤯
This is Stan's very first WFC, (the Dave Lawton replication). Technically, normal electrolysis...obviously not your standard DC electrolysis, and logically much more efficient, it is completely explained with known and established electrical theory, just applied in a method having a more complete understanding, it possibly releases more potential thermal energy via Hydrogen release than it consumes in electricity (needs adequate testing). It's not wizardry, and it's not "free energy", as we have to pay for energy to "tickle" the Aether. It's most likely over-unity, but It only requires an Aetheric underpinning of the Quantum realm. Organized, otherwise chaotic aether being what "voltage" actually is or directly coupled to...aether, most likely being a quantum particle and antiparticle pair, such as the possible free "quark" theorized and possibly seen in a few quantum experiments). This aether explains the energy gain, having a COP>1...like a heat pump can capture environmental energy, we have here a Quantum pump, gathering aetheric energy.
« Last Edit: June 19, 2023, 12:17:02 pm by Radiant_1 »
Re: My new approach
« Reply #181 on: June 19, 2023, 14:45:47 pm »
Thank you for explaning the tech better then i did  :)
cheers!
Re: My new approach
« Reply #182 on: June 20, 2023, 06:57:32 am »
Hope someone make it work don’t care who and how! Just not bill gates hahaha
Regarding Stan I’m quite comfortable saying that I don’t have any sure about his theory
That’s why I started to go into my thoughts only and what it makes clear sense in terms of basic physical principles
If there is some other physical principles to be discovered they must be distinguishable from what is know otherwise is just the same with other fancy name
The few things Stan told I keep is
The key is to generate electricity
Keep it simple stupid
When hit with resonance the water simply splits apart
The less I get from anywhere the closer I get to where I want after all if you believe blindly in someone who try to deliberately hide or mislead you stuff you will always be fooled
So if Stan says lot of things I don’t really care as no one can know what is and what is not correct until the god damn thing works
I have my hypothesis and I’m pretty confident but nothing is certain until it gets out the paper
Almos everything is set up in just waiting for the next move that is glue into the pvc pipe with maybe silicon
The lesser is the number of variables the easier is to accomplish the task
Stan talk about rocket science to explain something simple just to mislead you or mislead his investors who knows
He may even have be a dreamer or may have tried to copy something and never succeed
From the possibilities I grab the best I choose the most reliable and the only moments I can filter he is not lying
Re: My new approach
« Reply #183 on: June 20, 2023, 07:11:50 am »
Hey bud, no competition at all, I only wanted to share with you something I think is important, it's not meant to dissuade or change your direction whatsoever. There was a person who had a little hemispherical pair of waveguide, they claimed acoustic resonance and it made tons of bubbles. I don't doubt there's many ways...my only advantage in this world, is a freakish memory, and trust, it's a blessing as much as a curse. I've only ever been interested in getting it out into the public domain.
In Stan's defense, he put alot of time and money into it...he was going to lease units that people could come in and retrofit their vehicle with, pretty attainable for people on a budget. His real money maker was a contract with the Government, under Bush Sr.....hmmm
