Author Topic: My new approach  (Read 21777 times)
Re: My new approach
« Reply #168 on: June 15, 2023, 14:55:57 pm »
« Last Edit: June 16, 2023, 06:14:06 am by sebosfato »
Re: My new approach
« Reply #169 on: June 15, 2023, 14:57:53 pm »
Re: My new approach
« Reply #170 on: June 15, 2023, 15:27:15 pm »
I bought some 80 amps 3kv capacitors of different sizes
I think it was 250nf 10nf and 1uf may arrive in 20 days
Wanted to buy more but money is limited this days
Would be great to have more than 1 of each size adding in paralllel would increase current and in series the voltage
This are used in car wireless charging or induction cooking for example
Wish I had at least ten of each… ten of the 10n in series would make 1nf but would survive 30kv at 80 amps
That’s the way I’m going…
Re: My new approach
« Reply #171 on: June 16, 2023, 07:27:49 am »
Steve recently when I just let my phone get blocked what I wrote disappears
I’m not sure but seem like before this didn’t happen so often may be something with cache of the new post page
Re: My new approach
« Reply #172 on: June 16, 2023, 07:41:52 am »
To reach the max power this capacitor is rated for example the 10nf
Considering 3kv/80a 37,5ohm
With a coil 100uh 159khz it gives 100ohm meaning 30 amps Would already give 3kv
Here some formulas to easy up your calculation with a handheld calculator or excel etc
F= (2PiSqrt(LC))^-1
C= (((2Pi*F)^2)L)^-1
L= (((2Pi*F)^2)C)^-1
XL = 2Pi*F*L
XC= (2Pi* F *C)^-1
The equation that governs the apparatus construction seems to be
VL/nturns - VL + VC = 0
The first term is the cell voltage, VL and VC sums to zero at resonance
I = (VL/nturns - VL + VC )/R
The diodes voltage drop must get in as resistance equivalent for example it’s just not linear
And also the VL/nturns also depends on the current
So actually it is = Xc*I/nturns so it feeds back
Now comes the interesting part as it’s a transformer with step down the amps ratio gives the cell a very high amp output ability
Re: My new approach
« Reply #173 on: June 17, 2023, 08:21:31 am »
I was having a hard time to think a way of having it connected in series but all is needed is more plates!
So the diode voltage drop may become negligible if many cells are stacked in series
The coil have around 40 turns I may reform it better on to cover the whole pipe and to fit within the cc core hopefully
This will increase the inductance of the coil and let me play with different reactance
The gap will be very high so it will probably not saturate I expect the gap to be in the range of 8mm because of the pvc caps
This will bring frequencies down and reactance higher I may get a considerable Q factor with that capacitors  arriving
In mean while I have a 20uf 400v to test that seems capable of high current  and some minor capacitors around
Is important to not have water to form a closed loop as it’s going to act as a short ckt so the acrylic must cover all the region where induction is happenings
If we want to do it with a tube cell all you need is to have an acrylic plate closing half the acrylic reservoir and wrap a coil around it
The tubes will be siting each in a potential zone and let current output
I’m working with the core as I believe will be easier to have the volatge better distributed across the cell
I’m thinking of adding another set of electrodes just a small one in front of the electrodes to have bipolar output at anytime and maybe test different combinations maybe in this way the two stacks can be used in parallel
At the present time with only 4 electrodes it has the up set of electrodes getting to conduct during one semi cycle and the other set only on the other semi cycle
I’m thinking of using that blue silicon for molds to make the bottom seal and the seal of the acrylic with the pvc so it can be possible to open the cell and install other electrodes etc
Other wise I would make with epoxy directly but I’m almost sure I’m going to want to take it apart somehow later and so epoxy will necessarily have me to destruct the cell
Still deciding…
Today I took an old epoxy that is used for filling electronic components it’s very very dense and it was obviously all in the bottom very hard to mix
I took a copper bar and my drill and I took over 3 hours to mix it… I left it sit all day to get rid of bubbles
I’m going to get it hotter with the 3d printer hot plate as it’s cold here and it will take a lot to harden
I’m going to use it to insulate the wires and soldering that’s why I made that poket for the electrodes wires to sit in
I’m worried because if I place sulfuric acid or potassium hydroxide the copper wires  will suffer and dissolve ruining the cell or with any other chemical
The epoxy may survive better I’m using this type because I know the electrical characteristics of it
40kv/mm on data sheet
« Last Edit: June 17, 2023, 09:11:48 am by sebosfato »
Re: My new approach
« Reply #174 on: June 18, 2023, 01:34:06 am »
Hello, it's nice to see you never stopped sebo!!
Due to extenuating circumstances, I have been otherwise silent in the public domain. It's time for me to return to this endeavor. It was necessary for me to focus on other aspects of my life, but I am thankfully, now at a very comfortable place in life. I very much believe I have mentally suffered for denying my purpose.
That being said, I have never stopped working towards realizing the truth. I'm also happy to say, that the world is now ready to accept said truth. Advancements in science, specifically the intense focus on the Quantum realm, has the totality of Academia starring at the inevitable truth. That being, an aetheric reality must underpin all of existence.
That being said, I took time these last couple of days to see what kind of archive of my efforts still remained, doing so led me to Energetic Forums (I couldn't even remember I was active here for a few more years until looking for active forums and trying to register kicked me to recover password 👐). Reliving the event that got me banned over there, has proven very fruitful. Given my time to mature since my 20s, I re-analysized my theory on the "water fuel plug" and I'm pretty sure I have it ironed out now. I just want to preface this before I let it out. I was ultimately vindicated in respect to my judgement on that situation, in which Aaron totally wiped any record of. During a debate of operational theory. He shut me down, and then he attempted to belittle, and assign limits to cognitive ability on as a whole by saying "no one can ever understand how it actually works", all I did was point out the paradox of that statement, when he was, at the time running some sort of New Age Mysticism company/cult. Anyway, he went with his theory (that he and Lindemann were actually bullied into by an engineer lol) that the anomaly was caused by the forward primary pulse ionizing the airgap and then the capacitor just dumped the rest of the charge across the ion channel. Despite my attempt to offer several proofs to prove this otherwise, he never understood the true importance of that simple device (of which, someone on this thread, giving you testimony of Stan dumping a cap into the transformer, is %100 in line with my epiphany. Back then my explanation came to the correct conclusion, but was fundemental and over simplified). Out of greed he went on to patent automotive sparkplug, with his circuit, which he modified to fit, with the false theory of operation he also patented. I was bitter at first, but the plugs underperformed, were over priced, and the patents all expired due to non-payment of fees...lol
Anyway, my point is...it's now apparent that Energetic Forum, and his current forum is nothing more than free and R&D for their cult...It is my opinion, that Bearden was the only true talent, and they all faked their way to his side. They intentionally confuse and mislead to elevate their air of authority, and market themselves as gurus of this lost art to sell tickets/books.
So, I noticed that your last two video links on YouTube are broken...Is this still a safe space? I noticed hacking events taking place against this site, what is the current situation here?
Re: My new approach
« Reply #175 on: June 18, 2023, 02:33:49 am »
Hello my friend good to see you around… it’s being a while since the energetic fórum lot have pass… me too had a period of taking my life more priority… and also make some space and money to keep going and after some while here I’m back with some work…
The videos are broken I don’t know why I think is because is a shorts video and it may not display well in outside YouTube
If you go to my channel you can find it they are the same video I just tried twice to see if the link would work
I left that forum also a long ago when I moved to this forum as Steve gave much more space for discussion for us here…
I feel like a safe place to share some thoughts
Hope you can see the video this is going to be my new prototype I may finish this week to start testing
You keep your test rig ?
