Can you all read them as it shows up to me as just an Array.
Anyway, both Max and I have the system hooked up exactly the same and our wave forms are thus exactly the same despite outlawstc's inability to read the scope correctly. Think if it this way, if we both have everything hooked up the exact same way how could we have two different wave forms? Our wave forms are the same as the only difference is the load being placed on the VIC transformer. Plus outlawstc didn't bother to watch the video interview of my partner and I as that event is the "Global Breakthrough Energy Movement" that was held in Boulder, Colorado back in 2013 not the tesla tech. At that time Max and I were friends as I even offered to pay for the event for him and others offered him free room and board and were going to pick him up which is free travel but for some reason he didn't want to go.
This is the type of people I have had to deal with for a very long time concerning this technology people that can't reason to well and make things up as they go along. So again, how can we have two different wave forms if we have the entire setup hooked up exactly the same and are taking our measurements at the exact same spot? The only difference is the load that was being placed on the VIC transformer as I had mines hooked up to ten resonant cavities hooked up in series and he had his hooked up to two resonant cavities hooked up in series and the resonant cavities are the load being placed on the VIC transformer. After all this time you can't see that, really? We both have our setups hooked up exactly like this:
(http://i1025.photobucket.com/albums/y320/h2opower/4-23-20119_45_49AM_zpsa492807e.jpg)So tell me again how can we have two different wave forms? This folks is part of the problem plaguing this technology as some of the people wanting to solve this technology just aren't up to the task at hand. From reading your post you have no idea how to answer that question as you just failed to do so right here in front of everyone for the record. I'd be willing to bet your not laughing now, huh? And for the record outside of myself Max is one of the people I am pinning my hopes on as well as Ronnie Walker and his crew in case something happens to me. I've given up on Russ as his heart just doesn't seem to be in it. Moving on now as I have had enough of this Tom Foolery.
This technology at it's surface seems simple but as you dig into it you find out quickly that you have to take Meyer's words and translate them into a scientific meaning. I don't believe this was done out of stupidity on Meyer's part but as a way to hide the technology in plain sight as after all he was also a business man and who wants everybody stealing your ideas. So, with that in mind I set out to get at the core science that drives this technology and I found it after several years of research.
Water molecules can be broken down by taking the electrons away from the atoms that make it up, that is the core science behind this technology and Meyer used a strong ionization field to do so. This is also how plants break the bonds of the water molecules as they take away it's electrons. Now the method that these two different technologies use to accomplish this is different but the core science remains the same. So, any method that can get the electrons away from the atoms that make up the water molecules will work towards breaking the bonds of the water molecules. Meyer chose a method that didn't require much energy input which was creating a high voltage potential energy differential field as shown here:
(http://i1025.photobucket.com/albums/y320/h2opower/10_5VOLTAGECHARINGEFFECT.png)But again may I remind all of you this isn't what the actual wave form looks like as this shows an impossible situation but legally it can be used as it is just a block diagram. This wave form is from outlawstc which shows how the wave form actually looks like as again the drawing figure 10-5 shows an impossible situation:
(http://i1025.photobucket.com/albums/y320/h2opower/2015-08-09_112058_zpsvyspwktk.png)But the drawing shows Meyer placed a ionizing field on the water molecules which causes the atoms that make up the water molecules to start ejecting their electrons and again the core science remains the same. To get the highest level of amp restriction the B+ must be equal but of opposite voltage to the B- voltage. This is not an easy task to do but I have managed to get mines to within 100 volts of each other and sometimes only 20 volts but that doesn't get used as it falls in the error of the reading devices I use. The lowest current flow through the exciter array was measured at only 0.7 mA at 9kv potential difference measured across the exciter array.
