Author Topic: 101 plate cell, G board and Toroid ..........  (Read 25194 times)
Re: 101 plate cell, G board and Toroid ..........
« Reply #64 on: December 15, 2012, 04:24:18 am »
Thank you for the files Komtek, i didnt get to look at the first but i did the second one and it didnt mention the longitudal wrap or did i miss that part?
« Reply #65 on: December 15, 2012, 04:47:35 am »
Okay let me try with with compressed pdf.
The original pdf is over 5megs and I can't upload.
Try this, it should have the DC bias coil wind.
« Reply #66 on: December 15, 2012, 05:29:27 am »
kewl ... He's showing those longitudal wraps..  now that the rodin coil has came out i think it would be neat to stick one in the center of the toroid as a reciever coil?
Oldrich333
« Reply #67 on: December 19, 2012, 15:01:33 pm »
Dear friends,
with all humble I ask you a newbie type question, because I´m quite confuse. I understand, that you bought PWM3G curcuit and built toroid and buy or built 101 plate cell, and you did not get resonance/efficiency more than 200 %, am I right?
« Reply #68 on: December 19, 2012, 15:33:03 pm »
Hi Oldrich333,
Welcome!
Nick should really answer this but from what I have heard and read on this thread.
The PWM3G has not been tuned quite correctly to provide a resonance and the gas created thus far seems to be at a excellent rate for the power consumed.
Thus far it seems like a perfectly prepared cell (electrically isolated plates) and conditioned can provide at these higher voltages (because more plates) a rate of gas per liter at approximately 75-77 watts so far in just an electrolytic fashion.
I think if Nick can trully tune that PWM into a resonance he may experience even more output.
I would surely love to see that output rise or current level drop.
Also to add to this that its quite possible the gas produced is at a higher level of strength as compared to a standard dry cell.
« Reply #69 on: December 20, 2012, 04:44:28 am »
Here's what appears like an older Boyce video.
This cell is just an electrolytic cell.
I noticed he stated the spaces between were 1/8" but the slots were oversized and allow solution to pass around the plates and equalize.
Wasn't there a problem with this eventually?
Also I wonder if there is a certain amount of current maybe just a bit too much that the passing solution could create an arc spot.
Wasn't arcing an issue with many of these 101 containers.
If it was what was the current setting people would use on them. I wonder if in general many people were applying much over current.
http://www.youtube.com/watch?v=5nXFgfk-Rsk
« Reply #70 on: December 20, 2012, 20:45:05 pm »
Oldrich,  I can tell you this. I have been testing the B.B.101 cell for many years now. It has taken many design changes to solve the leaking and bypass issues. To date I HAVE NOT seen resonance in my cell. I have heard of others who have, but I have not seen even a video of a B.B.101 cell resonating yet. Do I believe it is possible with my current setup. YES, and I believe I have the cell to do it but as of this date, testing goes on. Like Seb said earlier there are no newbies or dummys here, only those wanting to learn. That is the purpose of this thread to hopefully solve this together.
« Reply #71 on: December 21, 2012, 03:43:23 am »
hey Nick, can you post some piks of your cells and scope shots of ur G board?
