Author Topic: 101 plate cell, G board and Toroid ..........  (Read 25147 times)
Re: 101 plate cell, G board and Toroid ..........
« Reply #48 on: December 13, 2012, 17:31:15 pm »
Well, he likes a mix of frequencys, because he thought that that worked better.... :)
« Reply #49 on: December 13, 2012, 20:36:58 pm »
You don't need a bunch of frequencies two frequencies with x6 spacing will do.. no OU ofc but helps fuel consumption.
« Reply #50 on: December 14, 2012, 00:09:12 am »
Bob directions are indeed correct, but his diagrams don't do what he says. but does other things...
what is he doing in the end?
Don't take my word here, you must understand by yourself's otherwise i would need to guide you thru everything and i need people to come aside me not behind me.
What does it not do specifically?
What other things does it do specifically ?
As far as whats he doing in the end... as for now he is making more gas than anyone with tube cells.... im all for tube cells as I think they may be a way to produce more gas than Bobs does but so far ...  not hapened yet :/
Im sure the fields behave diffrent in a tube cell than a plate cell but I have not seen no body produce more usable gas at the same temperature as Bobs does.Even if there is a day the tube cells prove to produce MORE USUABLE GAS, Bob doesnt deserve to be bashed about his work or put down in anyway shape or form.
« Reply #51 on: December 14, 2012, 00:21:27 am »
Sometimes we are not stupid just the schematic...
I don't understand how pulsing different primaries with different frequencies would help.
 it may be a 3 phase system using water as the load ;)
« Reply #52 on: December 14, 2012, 01:09:57 am »
Bob did not just find a way to make this toroid system work for HHO but he made some specific advancements with a multi-channeled setup using some more coils for DC bias on the toroid.
Don't know who he did this for but I'm sure it was a positive result.
Also from some old reading on his research with the multi-channel setup, he had some near miss horrific experiences.
I believe its because of the bad experiences he had, he shy's people away from researching with the setup.
I was never there and have not heard of any other persons factual representation of the evidence, so it may not be correct.
We need to hear of positive results with this setup and about the fine tuning of the pulse and width to show the proof of concept the system was designed for.
« Last Edit: December 14, 2012, 01:56:28 am by komtek »
« Reply #53 on: December 14, 2012, 09:43:25 am »
So, Geon,
Welcom to this forum.
Can you explain more? It seems you know more about this, if i read your comments well?
X6 spacings? What does that mean?
« Reply #54 on: December 14, 2012, 10:14:24 am »
x6 means two frequencies must differ by the multiplication of the first frequency by 6 minus the first frequency..google coherence..
Plus yesterday I realised how this frequency bombarment alters the surface tension of water droplets.. surface tension is very important aspect.
You will have headaches using toroids I suggest you use other shapes. Seriously toroid shapes are extremely complex to understand.
« Last Edit: December 14, 2012, 12:27:22 pm by geon »
« Reply #55 on: December 14, 2012, 11:54:25 am »
Thanks for explaing and sharing your surface tension experiments, Geon. I ll appreciate that.
So, if i understand you correctly, if i use 1khz as a basis frequency, you multiply 1khz * 6 = 6khz   and then 6khz minus 1 = 5khz.
A comby of 1 and 5 khz would break up the surface tension, as example.
Did i do yr calculation right?
