Author Topic: epg  (Read 15442 times)
epg
« on: May 27, 2011, 02:17:38 am »
Here is where I will post my epg findings.
Re: epg
« Reply #1 on: May 27, 2011, 02:20:34 am »
picture 2
Re: epg
« Reply #2 on: May 28, 2011, 00:40:12 am »
Re: epg
« Reply #3 on: May 28, 2011, 01:20:16 am »
Yeah it's copper, found it at work
the different sections have different numbers of turns, 50, 100, 200, 300, 400 turns. this way if I get anything working I can see what has the most useful output. I still need to wind a primary coil with a core so I can pulse it if I want too.
Re: epg
« Reply #4 on: May 29, 2011, 10:47:45 am »
Do you want to use hho thru these tubes?
Or water?
Re: epg
« Reply #5 on: May 29, 2011, 16:36:34 pm »
I'm planning on using Hho, the Canadian patents is what I'm working on first. I did notice something interesting about water today, my cell holds around 2 volts all the time, but when I turn the pump on and force water through the tubes I measure around 6 volts across my cell. This is without any power applyed, maybe water could be used? I don't remember reading anything about Stan using water in the epg?
Re: epg
« Reply #6 on: May 29, 2011, 19:25:30 pm »
Dave,
I've been pumping water through my 3" tubes out of curiousity since you started posting about it.  I've observed a rise in amperage on the meter as I increase the flow rate.  Do you see this?  Is there an explaination?  It is interesting, yet I observe no more gas output than without pumping water through.  I use a variable speed pump and have noticed that when run moderately it fills the entire cell volume, hoses and pump with milky bubbles.
kb
Re: epg
« Reply #7 on: May 30, 2011, 07:36:09 am »
kickback,
my results are a little different, I need to test further but I'll tell you what i'm coming up with so far. My tube cell is designed so water I pump in has to go through the tubes and cannot go around. I have it set up in such a way so the pump does not suck in the gas, but it does happen when I put the cell under pressure. With the pump on, my cell draws 10% more current. I found that I was producing almost 3 times as much gas this way. My tube cell is much larger then yours so that could have something to do with it. I'll test further and see what I come up with. The pump doesn't help anything when I have my vic hooked up, at least not yet
