Ok. I am not sure if anyone has put this together but here goes.
Stan did point out the theory/process in his Tech Brief and his patents and here is why. First I am going to talk about the principle of electronics of a general nature.
Electricity needs voltage and current. Voltage in electrical is pressure. Current is the flow of electrons per sec. So what is the flow of electrons which is current? Well you need voltage of course, but what voltage does is push the physical mass of the electrons physical mass which is the electron out of each orbit of copper or related material to produce movement to create electricity. The reason this can be done is the force of the outer orbit of the electron in copper is very weak. Voltage pushes the electron. This physical force of the electrons creates current. Ok.
Now if we look at Stans equation he points out out acceleration = Force/mass. Mass is the physical component and the Force is Voltage which is represent by the formula of two charges/radius^2. This is directly related to the flow of current.
So how does this work for Stans process. Well it is easy. The
physical mass of his circuit was directly relate to the atoms of Oxygen and Hydrogen aka(Water). The higher voltage is needed to push the physical mass of the atoms apart. The force of voltage does need to be in both opposition to each other. Meaning a high positive and high negative voltage on both sides. One of the positive voltage pulls the oxygen atom while the negative side pulls the hydrogen atom. The reason for the high voltages is looked at because you are pulling a very much larger mass.
Now I know most everyone know this but the point I am make is how his circuit does not use current. He is building a high voltage to create the force need to act on the water molecule. The only current draw is the circuit resistance getting to build a charge across the capacitor.
It is no different than the theory of electricity which has the same principles. Instead you are looking at it at a larger scale from the atom itself.
This is how voltage can work by splitting the water molecule!!
