Author Topic: Voltage does Work!!! And Here is why!!  (Read 24770 times)
Re: Voltage does Work!!! And Here is why!!
« Reply #80 on: January 28, 2011, 15:27:18 pm »
Hi sebos
in this vid gas coming off only from one electrode . This electrode have negative polarity. There is'nt
other electrode. It's like negative charging of water. (or the one electrode electrolysis )
andy
« Last Edit: January 28, 2011, 15:45:07 pm by andy »
« Reply #81 on: January 28, 2011, 15:57:35 pm »
Andy, what is happening in my opinion is that on the other electrode the oxygen is oxidizing the anode thus becoming a solid oxide and thats in my opinion why it don't come out as gas. And also this oxidazability of the anode maybe is the reason it is working too.
« Reply #82 on: January 28, 2011, 17:25:25 pm »
Donald i was reading old threads about electron extraction, and found that i should explain the time share rate of the covalent eletcron.
Oxygen being one of the most electronegative atoms in the periodic table like electrons very much. When it accept the electrons of the hydrogen during the combustion it takes the hydrogen electrons and robs them, making them to be most of the time in the oxygen orbit.
This makes the time share tend to the oxygen for the most part of the time.
Altering the time share rate relates to increase the hydrogen atom positive charge and or increase the oxygen negative charge so the hydrogen attracts more the covalent electrons and the oxygen repels the covalent electrons. This in turn obviously change the covalent force, weakening it by affecting the time share rate.
I learned this last year when i was frequenting the atomic and molecular physics lessons.
Stan say that when he electrically intensify the water atoms its charges become intensified, the hydrogen become more positive and oxygen more negative.
I guess giving the water a positive charge ejecting electrons would interfere in this. But i think that voltage also must be applied in there between the plates too.
« Reply #83 on: January 28, 2011, 17:43:46 pm »
thats Why when he talk about preventing the water molecule from reform initially he ionized the hydrogen negatively (so it repel the oxygen), and later only ionized the oxygen and water positively (cause probably is easier and thus it repel the hydrogen fracturing it stealing its electrons).
« Reply #84 on: January 28, 2011, 21:44:17 pm »
I made the test and some gas production using deionized water. I think that i'm on the track. I used one transformer outputting ac going to the outside of the container and the outer tube, and a the VIC connected to the inner tube and outside of the container.
Between the tubes there was 23 volts DC and 20 AC and some bubbles started to appear. This was the first test i did and was the better one. I tried to change the configuration in all manners i thought.
The primary of the ac transformer (flyback) is connected in parallel with the other primary. I'm not sure what is the frequency. Going into nor the power consumption, but is very low cause the mosfet does not even get warm.
I will tray adding a diode on the ac transformer to see what happens.
My problems are, meters and oscilloscope missing, and the circuit is not working very well.
obs when the ac primary is not connected to the source the flyback vibrates intensely.
The voltage between the water and outside now is only 17v dc...
Forgot to say
I'm not using the trains of pulses and other thing is that this deionized water i can input 400volts between the tubes  and no bubbles come out.
« Last Edit: January 28, 2011, 22:04:05 pm by sebosfato »
« Reply #85 on: January 29, 2011, 00:01:36 am »
Well done!
Cannot wait to hear more on this.
« Reply #86 on: January 30, 2011, 01:51:07 am »
Sebosfato,
Here's a simple way to test your theory.  Take a 110v to 24 v step down transformer and run the primary and secondary as chokes.  Mix and match the input output wires to reach the highest system voltage as in the 8XA.
Now, throw together a one gallon wide mouth glass leyden jar with foil inside and out and filled with salt water.  Connect this in parallel with your cell.  You will be in the 2-4 kv range real quick with few amps from your variac.
I'd like some confirmation of this effect I get with this arrangment from anyone else interested in trying it.
just playing
kb
« Reply #87 on: January 31, 2011, 20:03:59 pm »
Hello guys,
I cound't test in the last day cause i'm very sick, as soon as i get better i will come back to work.
I've read a lot recently and would like to recommend to you http://www.google.com/patents    PATENT NUMBER 2,948,861  CRYSTAL BAbb
This patent talk about Quantum MechanicAL Resonance
VEry cool this patent was cited by Lawrence Nelson patent
Hope you enjoy
