Author Topic: Herman Anderson  (Read 31958 times)
Re: Herman Anderson
« Reply #40 on: April 12, 2016, 05:40:15 am »
I cant agree with the usage of the hole...i dont think the hole is suppose to be there....i think its there as a result of using the electrode as an ion source and it simply got used up.I think if you can imagine an arrangement where air is used as the ion source (referring to the Standford study) the electrode may be less used up and last longer,the air hole should provide stress relief from the thinned out layer of the electrode as well.
Once you have the standing pipe arranged,cell preasure ,along with air being supplie atop the cell will circulate the cell water and help keep the chamber from over heating.
Another thing ive not seen mentioned is the pressure atop the standing pipe...you should build it and check that out.
« Last Edit: April 12, 2016, 10:12:12 am by KS »
Re: Herman Anderson
« Reply #41 on: June 04, 2016, 09:44:33 am »
Dear Kevin,
One other question for you.
Did the cell of Herman had a separator for oxygen and hydrogen in there?
Re: Herman Anderson
« Reply #42 on: June 05, 2016, 02:27:53 am »
Not that Im aware of...Herman did say you couldnt have one between the plates but up there referring to above the water line.
The top that Herman used has a baffle in it....there also was a huge hose going in pushing something thru the top (air,fog..??)
If he had some kind of slosh prevente it would have been on the outgoing side under the baffle part of thst top.
James did say that the cell after removing from the car had been leaking...the KOH had found its way out and had formed solid crystal like stuff streaming down...like a cave thing :)
Id bout bet he had some kind of slosh protector in the top .
My personal opinion and wat im fixing is a gas output from the standing pipe.The hole in the top of mine will be plugged and used only to add more KOH.
« Last Edit: June 05, 2016, 02:52:51 am by KS »
Re: Herman Anderson
« Reply #43 on: June 05, 2016, 10:20:28 am »
i read somewere that Anderson was venting the oxygen into the cars interieur.....
Was is that right?
Re: Herman Anderson
« Reply #44 on: June 07, 2016, 08:25:43 am »
Was is that right?
He mentioned it in the interview but it seemed like it was just something he was considering or hoping.with the top he had on it there would be no way.the top he had on his cell was part of a kitchen sink plumbing part....check it out at walmart or wherever....there was no way he was seperating the gas with that top....pluss he used a speciality designed, pressurized  ozonated water generator.
You can ozonate water to the point of looking like a cloud and steaming.
« Last Edit: June 07, 2016, 08:47:32 am by KS »
Re: Herman Anderson
« Reply #45 on: June 07, 2016, 08:34:47 am »
I think it shouldnt be much longer till we completely understand the magnetics of his system....ive watched his interview so much to almost memorizing everything he said.
Re: Herman Anderson
« Reply #46 on: June 07, 2016, 10:43:19 am »
Was is that right?
Yes. He said that in the interview.
Funny that you said that you almost know every word from that interview. Same here....
The shitty thing is that parts of that interview are soooo difficult to hear and to understand.
Specially if english is not the native language, as dutch is my native  one.
To come back to the topic:
Might it be that Herman said that he was blowing the warm air from the cell cooling system into the interieur?
cheers
Re: Herman Anderson
« Reply #47 on: June 07, 2016, 11:21:54 am »
If you combine all info from that interview and also the Horvarth patents we might understand a little bit more on what is going on.
Remember that Herman speaks of using a positive magnetic field to push the hydrogen trhu the waterbath as being very important part of the system.
Also the explanation of that old engineer at the end of the video is also important, Kevin.
I tell you why. Now its important to know what happens when you use a sparkgap with a coil.
You can find a lot of info on that in the Horvarth patents.
When air gets ionized in a sparkgap, a high current starts to flow into the transformer of Horvarth, creating a hugh magnetic field.
The field force is described in that patent!!!!!! Unbelievable.
Back to sweet Herman. He mentions the use of corona wire.
He used a round cylinder as cell.Combine that with the info of the other man wrapping sparkplug wire around his cell.
One and one = two.
Herman used corona wire around his cell to creat 2 effects.
1. radiolysis by emf fields
2. magnetic field for pushing the monotomic hydrogen
Corona wire with a sparkgap, probably below the cell.
Cheers
