Author Topic: Voltage Intensifier Circuit  (Read 56068 times)
« on: April 22, 2010, 01:50:08 am »
I now have warps set up, it arrived in the mail today, I'll be testing it soon, and warp, maybe we can have a chat on msn and i'll see if I can get your high voltage results again.
« Last Edit: August 14, 2010, 21:42:24 pm by Donaldwfc »
Re: Re: Testing of Warps chokes
« Reply #1 on: April 22, 2010, 13:05:12 pm »
awsome
« Reply #2 on: April 28, 2010, 03:42:44 am »
IT WORKS!!!!
over 2000 volts across the tubes, maxing out the meter, a little bit of gas production, the light lights up!
http://www.youtube.com/watch?v=LKeXES4mK5M
dark video... sorry, i'll make a better one soon.
It works!!!
« Reply #3 on: April 28, 2010, 05:16:39 am »
Thats a nice first video Donald
If it quaks like a Meyers and looks like a Meyers its probably a Meyers .
Case solved , Hydro kinda got ignored because it just doesnt produce 20Lpm with amazing rocket flame for 5 watts .
Seeing this makes me all sad and happy @ the same time , wish theyd be jumbo gas yet there it is , 2000 volts between 2 metal gaps with no coating on and regular water . Get that nice frequency that resonates with the water and you will succeed , like Hydro says . I for one believe that multiple frequencies are used , the total signal has sidebands if you will , sidebands are like component wave form , and I believe that the gating itself was more than just gating , yes there was gating for quantity control , but it was really other gating , he was probably gating the gated pulse trains is what I wanna say , gating was not used for just volume control . A couple of quotes from Stan just give me eery feelings about the gating , he callss for it being multiples of the frequency somewhere .
One thing that is similar with Puharich , Stephen , Stan , Rife .
Both Puharich, Stephen , use heavy sideband signals , Stan uses none but a single frequency ? I think not ....
If that thing works with square waves you should try my dc pulser , I believe I have posted it in A thread by Sebosfato of working resonance something , unfortunately i dont have that paint image saved since my hard drive died .
What kinda of water is that anyways
« Last Edit: April 28, 2010, 05:44:19 am by Dankie »
« Reply #4 on: April 28, 2010, 05:52:50 am »
Tap water, I will try distilled tomorrow.
I've been playing around with different configurations, and nothing else is working like that original set up in the video, i've been getting lots of different high voltage readings, and measuring between different places trying to understand it better.
Without the small chokes, it doesn't produce gas, hook it up backwards, no gas, no set up transformer, no gas, no diode, no gas
The power supply is 12 volt at max 2 amps, but measuring it is more like 9-10 volts, I'm going to play with this some more and see if i can get something on a scope, if i can get a hold of a scope.
The frequency range appears to be small, not the full audio range, I can't find resonance anywhere, I imagine if i can find the resonant frequency then the gas production would increase a lot, also gating like you mentioned... no gating on this circuit either
« Reply #5 on: April 28, 2010, 10:31:08 am »
Fantastic step, Donald!
« Reply #6 on: April 28, 2010, 14:51:20 pm »
Nice Donald !
Also find out what capacitance your WFC cell is (calculate it for one cell).
http://www.ionizationx.com/index.php/topic,1305.msg14449.html#msg14449
Then you can choose (match) a choke for resonance with your WFC cell in a fixed frequency range (step-up transformer)
http://www.see.ed.ac.uk/~jwp/radio/software/lc-calc.html
Then the frequency range of the step-up transformer. Can it step-up voltage for the necessary resonance frequency? Impedance matching?
There are still questions, what kind of input signal is used for the step-up transformer. Is it pulsed or sine wave signal?
Remember: when you have a pulse signal on resonance with only the step-up transformer you have max. voltage? One resonance frequency! All added harmonics form a sine wave signal from the pulse signal. Still I do not understand resonance with the WFC chokes and WFC cell on this frequency in combination with a step-up transformer?
As you may remember, I'm working on a isolated resonance cell, but my progress is slow. Not everyone has a lathe at home...
br,
Webmug
« Reply #7 on: April 28, 2010, 15:54:08 pm »
Here are some more comments:
I attached a wire from the ground of the power supply to the connection in between the secondary and the bottom choke, and this produced gas as well
I added my chokes in series after warps chokes before the cell and it still produced gas, and would light up the light
I removed warps chokes and just used my chokes and it still made gas, and still maxed the meter, lights up
I removed all chokes and just has the step up transformer, and this produced gas but would not light the light, still some high voltage readings
I measured the resistance of warps coils
Primary: ~1.7 ohms
Other Primary, unused: ~1.7 ohms
Secondary: ~59 ohms
Chokes: ~1.7 ohms both wires
I don't know how many turns or wire gage yet.
Thanks for the tips webmug, I'll get some measurements soon, I imagine the resonant frequency is out of the range of this pulsing circuit
