Author Topic: Voltage Intensifier Circuit  (Read 56020 times)
Re: Working Voltage Intensifier Circuit
« Reply #112 on: June 26, 2010, 20:44:03 pm »
webmug, that was measured as you can see in the youtube video, with the cell connected, measured from power supply ground to one side of the cell, also measured in between the plates, and across the tube light, in any case it's easy to get 400-500-900-maxed meter voltage reading... so i don't know exactly how this is working, it's not like a normal AC step up... I'd love to have a scope to check the input and output wave forms, it's on the list to purchase!
is the ESL transformer a WFC thing or another project? It doesn't come to mind but it sounds like it would be fun to work with.
At a guess, I figure it's not letting out more than 25 mA to the cell, give or take a bit, based on the gas production. The gas production is just from the amp leakage.... still working on finding resonance where the "water molecule just falls apart" as Stan says in the NZ video...
Which brings me to the Delrin Insulated Resonant Cell, which will be coming soon.
« Reply #113 on: June 29, 2010, 19:36:52 pm »
wow what's that?
btw a youtube embed function would be awesome here
« Last Edit: June 29, 2010, 20:02:51 pm by Steve »
« Reply #114 on: June 29, 2010, 19:50:35 pm »
wow what's that?
http://www.youtube.com/watch?v=5Gbt92dIKi8
Ill gues its just amps you see.......
Nice vid Donald, btw.
« Reply #115 on: June 29, 2010, 20:06:33 pm »
nice, embed  :D
« Reply #116 on: June 29, 2010, 21:25:27 pm »
That is the 8XA circuit, it was a video from May 29th, with tap water.
« Reply #117 on: June 30, 2010, 11:01:58 am »
@Donaldwfc
I'm just experimenting with that ESL for HV generation to see it also works on a broad frequency range.
For the 8XA circuit part, nice video! Have you verified the Voltage Levels (amps restriction) or did it only use max. amps.
http://waterfuelcell.org/Experiment%20objectives.html (fig .8 )
Great stuff, Donaldwfc!
br,
Webmug
« Reply #118 on: June 30, 2010, 16:13:30 pm »
webmug, without the variable spacing cell I can't really tune in, to numerous spots, like Stan could have, I suppose there might be one spot (or four, with 1, 2, 3, or 4 tubes connected) where i can tune in, but I haven't had any results there yet. I am not sure what the inductance/capacitance range I am working with so I might not be in the right freq range.
I am going to build the resonant cells next, and after that I may consider again, building a variable plate cell.
Also i'll need an LCR meter, and probably a new VIC that is better designed.
« Reply #119 on: June 30, 2010, 17:56:33 pm »
So, we are still stuck at Reaching Voltage Level One L1. If we could reach Voltage Level Six L6 the resonance cavity comes in. Right now a lot of amp inhibiting 'things' must be done.
