Author Topic: Thousands Of Volts Read (Directly) across tap water, (Tubes)  (Read 14457 times)
Re: Thousands Of Volts Read (Directly) across tap water, (Tubes)
« Reply #8 on: October 27, 2009, 18:07:31 pm »
Great job Warp.
To let it resonate with the water, what variables are to be adjusted? Not the choke size,and frequency,since they are tuned for maximum voltage - I think it is important to create a very small cell, like Meyer did in his later work with HV.
The production is not small when you're using 1 tube, However it takes time if you're using 9 tubes.
Try an extremely small cell. ?
The Freq of the Potential to come From the choke must be a Resonate Freq with the Water molecule. I have No Clue of the Freq coming from that choke, I know i Melted it in that setup a while back using milliamps and Rf waves. See the black on the choke? Rf did that not current. This can also give you RF burns at certain freqs.
9 tubes is all i had to offer, i did not have the time to construct 1 cell as i have cleaned out.
Sebosfato, Lets see you light a bulb with 9 tubes in parallel using tap water, YET with a bulb of such in PARALLEL with the 9 Parallel tubes.
It looks easy, you say it is easy, I have thousands of hours in this field, I know without a doubt you are full of shit, I know how lucky i am to be able to do this.
Do not dog me until you do it,, Because more than likely you will not be able to. As far as not leaving enough information for replications, I left more than enough, I left a video and i also give information on the Key parts in order to get this to work.
You are a Bad Seed for this technology, Dogging someones work claiming to have already done it. OK, whatever, I do not see you demonstraigting anything even close to what i have done. My videos is for those boys that want to take it to the next level, We will see just how long it takes for these guy's to replicate my work.
Its on camera, video live showing it can be done, Sebosfato says its easy, So, Lets see them replications. I bet sebo will be the first one to become a Failure at it. Show us your proof Mr Big guy.
BTW, when the light is not in parallel with the tubes, the voltage goes much higher,, Tell you what Sebo, lets see you just put 60 volts across 1 tube containing tap water, see how easy that is for ya, Remember, I Shown thousands on video already using just 1 tube, That video is here on this forum somewhere.  You can get the voltage across the negative terminal without any choke, The trick is getting it across the positive terminal as well, That you will fail at. But, watch my video for when you're in doubt big boy.
« Reply #9 on: October 27, 2009, 19:30:35 pm »
Hi, Warp, thanks for the info.
may I ask you something regarding the choke.
It is wound on the the smaller toroid, and there is only one choke on the negative side right ?
Secondly, does the HV across the water gap occur at a frequency band or is it at a  particular frequency point?
« Reply #10 on: October 27, 2009, 20:16:30 pm »
sorry warp i respect you and would just like to understand what you're doing. don't worry about me best regards!!!
Did you saw my video ?
« Reply #11 on: October 27, 2009, 20:20:56 pm »
Correct, the smaller toroid is the choke. Correct, just one choke. 1 choke is the same as 2, 2 chokes is only an illusion. In the meyer setup you can connect both chokes in series on the negative side, Or you can break them apart and connect 1 on each side, ("it does not matter").
In my video i shown 1 choke of 75 wraps on the negative lead using 24 awg wire.
I could have just as well used 2 chokes, Both containing 37.5 wraps, One for the positive lead and one for negative, This would be exactly the same thing as using One 75 wrapped choke.
You ask about the Frequency, I have no tools to comment on that, But, i know it is easy to hit Rf waves, And this setup can Smoke a choke using a small meyer vic 1" in diameter, it can litterly fry the copper coating and destroy it, it can burn your finger when the choke is cold to the touch due to rf waves, The choke is at its own resonance, it has its own isolated earth ground.
I found this choke, I do not know what would happen if another different choke was added, This you guy's can test and take to the next level, I'm done with it.
« Reply #12 on: October 27, 2009, 20:23:20 pm »
I haven't really had the time to watch your video. Dialup sucks. Forgive me if i was harsh, I'm only trying to share.
I want others to be able to enjoy the setup, it is up to them to get it to work, as shown on video. Once someone starts to replicate this they will see, the proper choke core must be used or you will not get voltage potential on both sides of the fuel cell.
The Secondary 36 awg primary is fully wrapped from one side around to the other, neatly. The primary is the half side of the core i later added over the Main 20 awg primary which goes all the way around, it was not used. There is no hidden Parts in that video, Nothing is hidden. The Video Clearly shows EVERYTHING that is needed to do what i done. I could have very well used a 1" in diameter transformer and gained even better results, "Current flow is restricted when voltage is present." The used lamped only tried to consume some current bringing the voltage down making it weak, It is clearly not weak when the parallel lamp is removed. Placing such a lamp between the Choke and Cell Does not alter the performance, Good amounts of gas can be produced with such a light between the choke and cell using a smaller cell.  This is why the size of the transformer does not matter. Do not make it more complicated than what it is, The setup is, Indeed, "Simple." However, The right parts has to be used, such as the right choke core.
« Last Edit: October 27, 2009, 21:05:16 pm by Warp »
« Reply #13 on: October 27, 2009, 21:03:25 pm »
thanks for clarifying Brian
« Reply #14 on: October 28, 2009, 04:38:55 am »
thus you are using rf waves.  :o
I also got the chokes burn but because i hit the transformer resonance frequency with open leads (believe me is almost impossible to reach rf with a 555 timer the maximum some of this chips can reach is 500khz)  and it became blue like a plasma ball after 15 seconds of the greatest ozone odor i ever smelled it got fire. Thats why i say meyer did it some way different from that witch is much easier to understand than it seems. However to reach his effect I found that you really need to reach high voltage he described. Check my video I show you how I put 570 thru the water very clearly please take the time to check. I also discovered how works his hyperdrive and steam resonator and why he used more than 9 similar vic unites in his buggy. Read my project check my video and just think about why would I tell you a lie? We already got it patented I don't care if all the world copy it for me is a good thing. Meyer told us the thru about voltage and amps being restricted while allowing voltage to take over on a dead short condition. Do you know why a voltage field is not consumed in an electronic circuit ??? Think about why a transmission line work at high voltage. Isn't it to allow the wire to cary more power with less dissipation? The voltage field flows from resonant capacitor to resonant inductor back and forth just as current flow but in opposite direction right. So you just need to put the water in the way. I can't make it cleaner than this.
Oh boy this is getting good
Now think about what I say and read what I wrote on my threads and you will understand is not possible that you don't understand I'm not joking here. We are at good point but money is needed i don't have any i just got a 20 euros donation (i thank you donator if you want show up) within 5 days is what i have on my pocket to buy what i describe on my project section i need to buy to prove it i'm going to do what i can to do it. I have many interest on this around here in the last 3 days and lots of progress.
Best Regards
Sebos
« Reply #15 on: October 31, 2009, 03:04:05 am »
« Last Edit: October 31, 2009, 03:20:38 am by Warp »
