Author Topic: Thousands Of Volts Read (Directly) across tap water, (Tubes)  (Read 14457 times)
Re: Thousands Of Volts Read (Directly) across tap water, (Tubes)
« Reply #24 on: November 03, 2009, 08:44:27 am »
Litterly Smoking the meyer choke. "Fire."
Also, Check this out, Be sure to check this out.. http://www.tpub.com/neets/book7/27f.htm
« Reply #25 on: November 03, 2009, 13:14:48 pm »
As the setup sits at work with voltage present, Kilovolts, There is 0 current flow in those kilivolts. The Goal is to use voltage effects to break the water. Now we have the knowledge of gaining such a voltage, Now, it should be tuned. Current flow I do not think is a good thing.
Any other arangement would destroy the circuits operation, Any arangement to cause current flow will result is low voltage being read across the cell. The circuit, its like its not complete, But due to the secondary polarity and wrapp methode it is complete, Its a Ghost circuit. I leave it at that.
EZ:
After getting a resonant potential, tune it to water by:
- Adjusting pulse off time without changing pulse frequency
- Change the voltage, it is a physical field, too high voltage will give overlapping fields - HV was intended for the watermist injector.
You are correct with standing waves you mentioned.  :)
« Reply #26 on: November 03, 2009, 15:33:13 pm »
One of the main reasons I shared the setup is because I do not have the time to test it. I dont have a scope either. What you said to test sounds like fun though.
« Reply #27 on: November 04, 2009, 00:59:57 am »
Let me know if this link doesn't work.
http://cid-b8d13afd374bc1de.skydrive.live.com/browse.aspx/Brian%5E4s%20Stanly%20Meyer?uc=2
This Is The CORE that I am talking about, Nevermind the transformer which contained an internal choke . Not a must. http://uqtj3g.blu.livefilestore.com/y1pgpSUoFTGfB-VwqkbkMF-pmDIfsx5vAmHd2LfS6Z54C2gdfYlfyJal1In1GpXjZtuui1kszwv2PzBKuMj3PtxdQ/Choke.jpeg
« Last Edit: November 04, 2009, 06:54:42 am by Warp »
« Reply #28 on: December 03, 2009, 07:31:59 am »
Is there any merit to winding the bi-filar choke on a toroid?  I'm almost thru with the wrap on a T- 40026  Micrometals core, one layer bi-filar with 22ga.
Needless to say, it is an arduous task.   When done, I'll carefully pair the wires for minimum proximity and then epoxy the beast, and mount it on a pretty acrylic stand with screw terminals.   If it looks good I'll put it on ebay <grin>
I'll probably just fire the HV solid state DC relay with the frequency generator and take it from there.   7 tubes paralled in my vision cell setup. http://s237.photobucket.com/albums/ff213/keithturtle/?action=view&current=visioncell001.jpg
Turtle, slow
« Reply #29 on: December 04, 2009, 05:17:01 am »
hey turtle, No, its actually really simple. Just wind the small toroid with 75 wraps in my case. Again the core is the "Trick" to gaining the voltage,,, Must have right core to see the voltage across the cell. Stick a flouresent lamp in parallel with your cell when it lights you know you found the right core.
« Reply #30 on: January 08, 2010, 06:07:14 am »
Warp,
I have a few questions for you,
1, what type of diode was that in the video? (specs please)
2, where did the red wire go to - between the xformer and choke?
3, do you think the white wire after the choke made a difference, small inductance with the 3-4 loops?
Also just to verify, connect to a water cell, pulse with a simple circuit, and grab a light.  if it lights up I have the right choke.
What was the turns ratio on your x former, input voltage also.
I think you said 75 turns 22awg on the choke for testing the effect.
Do you think the x former core has to be special also?
Thanks for getting me up to speed here.
« Reply #31 on: January 09, 2010, 08:02:21 am »
No. 1 Diode specifications; unknown and glass passivated oval shaped. I don't think the type is crucial.
No. 2 Between Transformer and choke was an isolated ground adjacent from diode.choke.
No. 3 Small inductance from Terminal wire had no effect.
No. 4 the light will always shine on the positive terminal, your goal is to get it to shine on the Neg, & parall.
No. 5 I don't find the Step up core to be crucial.
Contact my hotmail account by using the coatsbrian before it. Have the core I will find it for you, send to me your Address so i can ship. I have no time for it. The core will be left with you and in return you show others its affect. I've read 10 books in 2 months, one weighed 6 lbs. My mind is not near this, I've also been programming crucial code for calculations, My brain is a wreck , my time is very very limited. Take the core while you have the chance and see for yourself.
My mind is on other things, and may be for a while, And the longer the more i forget about how i've done certain things.
