Author Topic: Thousands Of Volts Read (Directly) across tap water, (Tubes)  (Read 14512 times)
Re: Thousands Of Volts Read (Directly) across tap water, (Tubes)
« Reply #32 on: January 09, 2010, 14:46:38 pm »
Dam warp , thats alot of books .
We had one of those books to read this year , it was pretty heavy but I probably read only 300 out of the 1000 pages , rest is for next year . Electrical code  ... What you will do for that piece of paper lol . I certainly was not under the same pressure and stress you were on . Any white hairs now lol ?
Its definitly an outstanding achievement , you showed alot of brains and willpower to read all that in such short notice , and under so much stress, you must be feeling good now ?
Anyways , wish you all the best to you and your family . .
as I promised , I will be sending you and jolt my pcb and parts list once im finished , maybe Steve as well . So close now...
« Reply #33 on: January 10, 2010, 09:09:12 am »
Warp,
I am afraid my testing would be limited to just letting everyone know the inductance of the choke.
Beyond that I would be expermenting - as you have already done.
(don't get the wrong idea here, I would love to have the core and experment with it - but I feel it may be better in someone elses hands. I will check my cores and look for the effect.)
Warj1990
« Reply #34 on: March 02, 2010, 08:03:11 am »
Dynodon Now has "All" the stuff I shown in my videos,,, "Accept the tubes." There is Absolutely no reason to why he will not be able to perform and show what I've shown in the videos.
I've ask him to share his results,,, "When he gets time to do so."
This,,, Infinite VOLTAGE across tubes has been Passed to dynodon,,, I have no way to test anything right now due to my new business.
I ask you, Please do not,,, Do Not let this Information Die, As Stated,,, And, Clearly pointed out,,, The secret is in the Material of the "Choke Core."
Also as pointed out,,, The Resonate Action of the water Molecule Must be tuned In using the Proper Freq. There May be need in Researching and testing "Diodes." Where it is clearly pointed out here that each Diode holds an Unique set of waves, Amplitude heights caused by different diodes Vary, On and off time also varys per diodes,, Most importantly,,, ("" The Blocking Affect. "")
A Diode Rated At 600 Volts,,, "Which is what I sent dynodon" Means it will Block Up to 600 volts, Beyond that and the diode will become damaged to Back EMF.
Diodes Rated for 30k Volts may have a Slow triggering ON time, A Delay causing a lack of Potential, Most high rated Diodes can't pass amps or switch fast enough. The diode dynodon has is ideal, Its a close path.
Very Small Zener Diodes have "Great" affects even though they are Normally Looked over, Don't have doubts about such a small diode, you may be suprized of its affect as I already discovered.
When the circuit is Improperly constructed, "My Circuit" the diode will surly get HOT. This setup does not Heat the diode when properly running. If the diode becomes heated something isn't right, Shut it down and reconfigure your connections.
Dynodon will share with you what he has, And i've already shared everything.
You wanted "Voltage Potential" across "Tap Water" in the thousands of volts - Now you have that.
« Reply #35 on: March 02, 2010, 08:39:26 am »
There is Not Enough Views of this channel only 128.
http://www.youtube.com/user/TheBrianCoats Share this on other forums.
This Information Should Not Die like this! Share it http://www.youtube.com/user/TheBrianCoats
"I Don't have the Time to post this on other forums."
« Reply #36 on: March 02, 2010, 16:30:15 pm »
Thanks warp, I hope we can figure this out and get some results, I hope to be doing a lot of solid state testing when I get more time in the summer.
I hope one day you'll return to this kind of project, maybe when we get some more things figured out and you have some free time.
