Author Topic: Daniel Dingle Patent Found  (Read 23326 times)
    • dudleys basement
Re: Daniel Dingle Patent Found
« Reply #16 on: May 23, 2009, 04:13:38 am »
this is not a patent this is an application for a patent  which is generally a breif one page description of what the patent pending will be     you can tell this by looking at the id number it is followed by A1 if it were a patent it would be B1
also application has a statment to federal sponsored research in claim 002    meaning  if it were ever issue it would be free to everyone and only credit for the invention and not ownership would be granted to dingle
  • Yes I got Jolted,
« Reply #17 on: May 23, 2009, 05:23:55 am »
HAHA, that explains the poor document.
Thanks Dudley for clearing that up.
« Reply #18 on: May 23, 2009, 10:45:37 am »
Thanks Dudly!
« Reply #19 on: June 21, 2012, 18:37:00 pm »
That patent don't have more sense.. however there are some difference from Meyer and Dingel.. Meyer use ionized water/air mixture instead Dingel use just brown gas in high quantities. In all case also Dingel use ionization inside the cell associated with standard electrolisys. Regards
« Reply #20 on: June 21, 2012, 18:53:11 pm »
Hello tutanka,
What kind or degree of ionization you mean in the case of dingel? He achieve it with the spark coil?
Regards
« Reply #21 on: June 21, 2012, 18:59:16 pm »
I don't have tested but from video I have imagine that scenario..
Dingel use an little welding power supply that use as ionizer, the positive cable (red cable) of ionizer is connected inside the cell to an steel grid  immersed horizontally on tap water for 2cm, under the grid are present the standard plates connected with 12V battery.
« Reply #22 on: September 20, 2013, 20:34:29 pm »
Was wondering about the honeycomb grid if its stainless.
Then underneath is the bismuth and Neo magnets that make up the positive section.
Does anyone have the capability of using bismuth and neodymium as one electrode?
In Dingles first page of the application he states nuclear energy and that's where the bismuth must come in maybe?
  • let the voltage do the work
« Reply #23 on: September 21, 2013, 09:34:04 am »
bismuth isnt radioactive
