Author Topic: Daniel Dingle Patent Found  (Read 23196 times)
Re: Daniel Dingle Patent Found
« Reply #8 on: May 21, 2009, 08:43:32 am »
@Outlaw
hydro has always said that are cars are the most wastefull in non efficient machine made.. i think i see where he is coming from.. gasoline is nothin more hten carbon and hydrogen as we all know..   i would say the reason why we are so wasteful is no matter what earths air doesnt have enough oxy in it to fully catalize the fuel and burn it completely..thats why we have a catalitic converter to try to burn off the rest..  thats also why they make super chargers and air blowers for performance..
The reason ICE engines are inefficient are for two reasons, first is the incomplete burn...but this is because car companies do not "Atomize" the fuel (look up fuel oil backpacking stoves), instead they use a fuel injector to spray tiny drops (many many molecules)....then they restrict airflow with crappy intakes. It's not because there isn't enough O2...it's because the physicality of the dimensions and poor air flow, mixed with too big of drops to completely burn (the intense heat from a complete burn would need to be addressed too)
Secondly, the "Prime Mover" in the system is heat transfer (expanding air). Most of that heat energy we make is just wasted OUT THE TAILPIPE.
All cars need to "atomize" (literally means single atoms/single molecules...easiest way is with heat) their fuel first...then the exhaust needs to be fashioned much like a radiator...have that radiator section boiling water for the turbine to then create high voltage energy for the production of hydrogen/oxygen, and surplus energy/electricity for w/e!   ;D  In fact this is what Dingel needed to do, his car starts on gasoline then is switched over. This is how the GEET system works too!!
@Mikemongo
Dynodon I hope your reading this  as you have seen this firsthand.
I was thinking of the air processor and started looking at the photo of Stan's latest stuff (injectors, solenoids, laser distributor, butterfly air gate, etc.
Is the air(gas) processor under vacuum...where is the butterfly air gate located?
I know at least one of the photos makes it look like the air(gas) processor is sucking air directly in, but I know that's not right without an air filter.
This is on my mind right now and I'm posting this before I go looking through the photos again, but it's stuck in my mind and I think it's important to know where that butterfly air gate is located because there's no reason not to just use the carb butterfly gate if the air processor isn't under vacuum.
Mikemongo
Stan's Gas Processor does sit on top the manifold, above the butterfly. (No carb...Gas proc.... throttle body/air intake...then gas injectors
Since the Gas Proc. is on the intake it experiences a vacuum...the same vacuum that sucks air in through the carburetor. (It was pictured w/o a filter is all...I have patents where the filters there.)
31 is the filter
32 is a restricting device (solenoid valve)
20 is the Gas Proc
(http://i175.photobucket.com/albums/w152/Jdub6d9/Untitled-1-2.jpg)
(This is kinda in the wrong thread...but I wanted to address this too...)
« Reply #9 on: May 21, 2009, 09:35:49 am »
http://www.newobjective.com/electrospray/
There was a patent allowed for a fuel injector for  gasoline that revolved around this . Let me remember that patent , I made a post of this on OUpower.com
It was a replacement for the spark-plug and was itself a spark plug at the same time .
« Reply #10 on: May 21, 2009, 09:42:19 am »
http://www.youtube.com/user/wwwshark
The process itself is called : electro spray ionization
It is used is mass spectroscopy .
« Reply #11 on: May 21, 2009, 09:52:31 am »
That's a beautiful spray!...Ya we need injectors like that in our cars.
The way I was thinking was like this
http://www.hiking-gear-and-equipment-used-* -Stove.jpg
See the tube running over the burner? When you start it up it spurts out a stream of liquid fuel oil. It go to a lil wick and light like an oil lamp. The heat quickly raises in the tube (carrying the fuel oil) the heat changes the fuel to a gas and gives you a clean burn. That is "Atomization"
« Reply #12 on: May 21, 2009, 10:37:12 am »
How come my above post isn't showing up? Took me forever to word it and get links/images...and, it says the stuff is in there when i go to edit it ???
Sorry Radiant. That sometimes happens. I am looking into it..
Did you had a youtube link in there?
Br
« Reply #13 on: May 21, 2009, 13:58:25 pm »
Ya it had two youtube links...I tried taking em out and it still didn't show up...
Ha, i know. When you write a post, you see many button above, for fat, underline etc etc.
You must use the button left under, when you wanna add a youtube link.
It looks like a white square, with a red v
When you use that, you can put yr youtube link in the code....
« Reply #14 on: May 22, 2009, 19:01:35 pm »
According to DanielDingel.com there is no patent :  http://danieldingel.com/node/15
But this page is explaining some of the patent : http://www.jcmiras.net/jcm/item/75/
Dingle mentioned vacuum : http://www.youtube.com/watch?v=KMXz6XEXKns&eurl=http%3A%2F%2Fdanieldingel%2Ecom%2Fwatercar&feature=player_embedded
« Last Edit: May 22, 2009, 19:29:32 pm by WaytoGo »
  • Yes I got Jolted,
« Reply #15 on: May 22, 2009, 20:02:10 pm »
Well, something is not right because as you can see here it is, his patent
