Author Topic: Impurities extractor  (Read 6845 times)
Re: Impurities extractor
« Reply #8 on: January 18, 2009, 22:27:34 pm »
Hi Dankie,
I still have to run some tests to find out what exactly the brown stuff is and is it has any magnetic of electric attraction.
Hope others will join in there.
Yes it does , I will edit my picture above and show that the pump is meant to go with the cell , its also needed for the conversion kit .
Yes I believe this is key to have a nice healthy durable cell .
« Reply #9 on: January 19, 2009, 01:21:24 am »
I have just tought of a new conception .
I will call it the SUPER-MEGA inner outer vortex coupling infinite black hole of no escape of despair
« Reply #10 on: January 19, 2009, 09:13:01 am »
That name is too long.
How about: the dankie vortex ? ;)
« Reply #11 on: January 20, 2009, 01:05:33 am »
I believe I understand the concept now , this is very needed so you dont accumulate impurities in a big cell and its used for the injector to turn tap water into perfect distilled good dielectric . I believe 100% pure water can be attained by magnetic filtering .
I have another idea wich is different from this as both magnetic fields from the coils go inwards and the current passes throught the impurities from one coil to the other , this is indeed an excellent dual usage design . With enough voltage this thing will suck up anything remotly ionic and leave nothing but pure water .
Im gonna manoeuvre around the resonant locking and find the pattern for starters  . Control the temp old fashion way ... Ill have a much more stable PLL circuit if I stay within a tiny margin thats if I need one at all ...
This is within my grasp , I'll use stainless steel wire so I can make this small and less amp consuming . Ill probably go into the range of  2-3 KV input in a small enough compartment .
Dankie vortex
« Reply #12 on: January 20, 2009, 19:01:30 pm »
« Last Edit: January 22, 2009, 04:49:30 am by Dankie »
« Reply #13 on: January 20, 2009, 20:04:15 pm »
Interesting theory, Dankie.
Do you find time to do some tests on this? Or are you bussy winding the VIC?
