Author Topic: Winding the VicCoil  (Read 19080 times)
Winding the VicCoil
« on: December 28, 2008, 00:41:39 am »
I own a CNC Coil Winding Machine.  I bought 6lb of the 430FR SS wire from Dankie.
I have the bobbins I intend to use for the Vic Coil.  If anyone would like for me to wind their coil for them I will for nominal fee to cover my time and material.
I have tensioners for all sizes down to 48 AWG
I have in stock
Thermalex /200 (heavy build)
41 AWG
36 AWG
28 AWG
Thermalex /200 data sheet attached
« Last Edit: December 28, 2008, 01:20:20 am by johnbostick »
Re: Winding the VicCoil
« Reply #1 on: December 29, 2008, 19:45:16 pm »
I dont know if it was by pure luck but you stumbled on almost the perfect ratio . Good work John .... you lucked out on this one ...
I will try to respect Stans words... I  will respect the ratio of wire circumference ... Stan suggests 30 awg wire for primary , 44 awg wire for secondary and suggest 38 awg for the stainless chokes  ( .004 )
So stan suggests .004 wire .... but we have .005 ..... but stan suggests .006 for the coil @ figure 10-4 ... so I had to split the middle and go .005
He suggests 30 awg for the primary  (.01 inch) , the circumference of .004 wire is about 2.5 times less than .01 wire .
The circumference of .005 wire is about 2.5 times less than .0126 wire ( 28 awg )
The circumference of secondary wire .002 wire is exactly 2 times less than .004 wire
The circumference of .0025 wire ( 42 awg ) is exactly 2 times less than the circumference of .005 wire ( 36 awg )
So in the end , I will be buying some 28 awg and some 42 awg  magnet wire .
Both will be made of heavy-build coating .
Analysing this video closely , I can say that the shape of the letters (and numbers ) from the primary look pretty much identical , same distance... everything.
So I am 99% sure that the dimentions have not been tampered with , so imo , if Stan himself  is standing in front of this , this is indeed viable information .
http://www.youtube.com/watch?v=X6hJEmw3mes
« Last Edit: December 29, 2008, 20:20:12 pm by Dankie »
« Reply #2 on: December 30, 2008, 05:15:58 am »
I need some help figuring the inductance values for the primary and secondary winding of the VicCoil
I've got the figures for the inductance of the chokes if 430FR is figured the same as copper
@ 11.6K ohms
36 AWG Choke x 2
Coil as designed with my bobbins
Inductance = 35 mH
Core Dia. = 16.54 mm
Wire Dia. = .152 mm
Core Lg. = 100.6
Turns = 3610
Coil depth = .8 mm
Wire Lg. = 196.58 meters
« Reply #3 on: December 30, 2008, 05:23:49 am »
Impossible to calculate on paper ... you make it then calculate ... I dont know magnetic wire reacts here  as people rarely make coils with this ...
This is something you will have to measure after .
All values will change when its all stacked together , this is where the efficiency somes from .
« Last Edit: January 01, 2009, 01:20:50 am by johnbostick »
« Reply #5 on: December 30, 2008, 21:27:33 pm »
I'm concerned with the voltage amplitude.
Looking at JohnB's primary to seconday is based on a 3 times boost.
Should we not want to get a boost to 1kv or more at least in our VIC's.
Also what is the start volts, shouldn't it be based on 12v because its already available in the car battery with out all the added extras of inverters etc.
Checking back and forth I am noticing several different VICs...
Doc or memo chapter 7 Meyer states S/S430 and primary of 22awg with secondary of 35awg.
You are mentioning chap 10 I'll look into that.
Trying to get on the same page is tough sometimes.
Thank heavens for Dankie getting the exotic S/S wire as I'm sure this is key!
So as you can see I have some confusion.
I'm all into several different VIC's as they all end up doing the neccessary ends we need.
« Reply #6 on: December 30, 2008, 22:20:33 pm »
I also believe there will be a high step-up ratio... It would be required to test ...
Yes 12 volts .... that would make sense and respects the kiss mentality .
Listen to this video ... @ 7 minutes
http://www.youtube.com/watch?v=hSlF7khibs0
« Reply #7 on: December 31, 2008, 19:04:52 pm »
Did you notice that in 6-1 the secondary is only connected on 1 side.
How does your core look like?
Meyer said it must have a closed loop magnetic induction path as in 3-23
I believe the coil segments in 6-1 are individual stacked coil bobbins electrically interconnected, the long single segment of the primary is winded in both directions.
« Last Edit: December 31, 2008, 20:02:58 pm by Alan »
