Author Topic: Stevie1001  (Read 12965 times)
Stevie1001
« on: December 06, 2008, 20:56:16 pm »
Hi,
Here is my project about ionization of gasses.
As you can read in the basic setup manual, i use ambient air for slowing the burnrate of the hydroxy mix.
So, i am investigating what the effects are when i ionize the ambient air, as well as the hydroxy gasses.
The less electrons in the mix, the better! ;)
The ideas are to use photons from LEDlasers at certain frequencys accoording to the Bohrmodels of hydrogen AND oxygen.
The other idea is to use High Voltage.
And the last idea is to plug the free floating electrons out of the gasflow by use of an EEC. An electron extraction circuit as Stan Meyer descriped.
Re: Stevie1001
« Reply #1 on: December 06, 2008, 20:59:15 pm »
Hi,
I build me a small tubular cell with 5 tubes. It consumes at 13V an amazing 8 amperes.
This cell will be build that it can contain lots of pressure.
When you want to try ionization by High Voltage, then you better be sure you have pressure.
With no pressure, you will blow up yr cell.
So, becarefull replicating if you want to use HV.
Here is a picture and a video of the new testcel.
Re: Stevie1001
« Reply #2 on: December 13, 2008, 19:35:09 pm »
Work in progress:
Re: Stevie1001
« Reply #3 on: December 13, 2008, 19:36:03 pm »
Another 2 pics of work in progress.
My goal is to have 2 of those panels.
Next week number 2 will be ready. I already found me a nice plexiglas tube.'
I am gonna add these panels on the outside. Rest of tube will be coverd with alu foil for reflecting purposes, in the hope the light will bounce.
steve
Re: Stevie1001
« Reply #4 on: December 13, 2008, 20:17:03 pm »
I hope you have a good flashback arrestor because if you manage to ionize those gases with high voltage and lights and get into the 2.5 million barrels of oil for a gallon of water you will kill yourself ...
Re: Stevie1001
« Reply #5 on: December 14, 2008, 16:51:53 pm »
steve
Hello Stevie
Why are you using 4 different colors is it to cover a hole range of frequencies NM.
Najman
Re: Stevie1001
« Reply #6 on: December 14, 2008, 22:19:46 pm »
 Stevie googled all the relevant wavelenghts and is trying all of them .
« Last Edit: December 14, 2008, 23:23:13 pm by dankie »
Re: Stevie1001
« Reply #7 on: December 14, 2008, 23:06:38 pm »
Stevie , do you have a 935 nm GaAs in there ?
