Author Topic: deleted  (Read 4945 times)
deleted
« on: November 13, 2008, 20:49:36 pm »
« Last Edit: May 10, 2009, 15:48:36 pm by HMS-776 »
Re: Capacitance, Temperature and resonance of the WFC!
« Reply #1 on: November 13, 2008, 20:55:38 pm »
I think this is out of reach for now .... eclipsed is working on a simpler , faster circuit ...
I personally dont think this is necessary , just because he never mentions it beyond chapter 5 .... nada ....nothing ....
He seems to have found a new ways to limit amp flow and still get a high voltage signal
  • Yes I got Jolted,
« Reply #2 on: November 13, 2008, 21:00:29 pm »
HMS-776,
what capacitance meter do you use?
When I try to measure capacitance on my WFC, the meter never finds a value.
do you have your tubes insulated?
« Reply #3 on: November 13, 2008, 21:07:00 pm »
« Last Edit: May 10, 2009, 15:49:37 pm by HMS-776 »
« Reply #4 on: November 13, 2008, 21:11:53 pm »
« Last Edit: May 10, 2009, 15:50:01 pm by HMS-776 »
  • Yes I got Jolted,
« Reply #5 on: November 13, 2008, 21:28:10 pm »
Ha.. there is my answer..
my tubes are not insulated at all.
I don't think Stan insulated his cell at all. maybe I'm wrong.
« Reply #6 on: November 13, 2008, 21:40:40 pm »
« Last Edit: May 10, 2009, 15:50:25 pm by HMS-776 »
« Reply #7 on: November 13, 2008, 21:49:17 pm »
I think this is what Stan calls the amp inhibiting effect  , this kind of effect is a must..
Here are a few quotes from section 7
Inductance of the positive choke performs "Capacitance Charging Effect"; while, at the same time, Inductance of the negative choke restricts electron movement
 negative choke locks onto Electrons Magnetic Field to block the movement of electron flow toward Positive Voltage Potential... thereby preventing and inhibiting electron-flow to pass through or arc-over water-capacitor gap, such electron blocking action is herein called "Electron Inhibiting Effect".
Electron Inhibiting Effect in direct relationship to Voltage Enhancement Effect is accomplished since stainless steel 430F/FR wire-material is "Electromagnetic Inductive" to incoming electromagnetic flux-lines without inductor-wire-coils becoming permanently magnetized... paralleling and performing the same electromagnetic characteristic of copper wire when it comes to magnetic field reformation that encourages, brings-on, and perform Voltage Inducement Process without amp "influxing" (inhibiting amp flow) between Positive Voltage Potential and Negative Voltage Potential electrically applied across Resonant Cavities."
