Author Topic: Impedance matching  (Read 2878 times)
Impedance matching
« on: November 12, 2008, 15:37:55 pm »
Hello,
let me start with the question:
We know how L's and C's react to sine waves, but how does it react to pulsed signals?
Should we consider the pulses as composed Fourier signals to let it react as wished?
I am not sure, but I have a feeling matching only to the pulse frequency is not enough.
Maybe I am mistaken and making it too comlex than needed.
Re: Impedance matching
« Reply #1 on: November 12, 2008, 19:51:06 pm »
Well I can tell you this.
Impedance matching is used to get the maximum power to flow to the load.
Power is Voltage X Current and is measured in watts,
Power is not voltage but a combination of current and voltage.
Impedance or Voltage Bridging is used to get the maximum voltage to flow to the load.
If your using Brute force electrolysis you may have something to gain by impedance matching, but when your going for voltage I believe impedance bridging may be more important. I have not done anything to prove this out but am merly just citing what i have read in the past.
I know steve meyer has a patent which uses impedance matching circuits, so it may be of importance, but he was also using alternators in his setup which produce current as well, so I cannot draw a conclusion on what exactly he was doing there.
Sources:
http://en.wikipedia.org/wiki/Impedance_matching
http://en.wikipedia.org/wiki/Impedance_bridging
