Author Topic: unipolar pulse trains  (Read 99307 times)
0 Members and 32 Guests are viewing this topic.
Re: unipolar pulse trains
« Reply #72 on: November 18, 2008, 04:56:58 am »
distributed capacitance looks like a pain to calculate ... I dont think i am up for this i guess it will be trial and error.
« Reply #73 on: November 18, 2008, 22:07:50 pm »
http://www.govliquidation.com/
thank you for this but i see that almost everything comes in a "lot".....of more than one object.....and although the prices may be cheap it seems the shipping costs more than the auctioned lot......
i need a spectrum analyzer for i have no way to calculate the resonance of the charging choke......since the capacitance is a changing factor with it's peak point at resonance.....i cannot mathematically calculate a resonant frequency if the capacitance changes with frequency...i need to apply a frequency sweep and visuall find the point with an analyzer.....once this is done my charging choke will be able to properly create that second pulse on the off pulse of the square wave.......then we have ourselves the proper working circuit.
IF THERE IS ANYONE OUT THERE THAT HAS ONE OF THESE I WILL GLADLY RENT IT FROM YOU......JUST SHIP IT INSURED.....I WILL RENT IT FROM YOU SAY ...VIA PAYAPL........THEN SHIP IT BACK INSURED.
i think i will try to go to my university for one or my local surplus store.
« Reply #74 on: November 18, 2008, 23:11:02 pm »
well, i want a spectrum analyzer  too!!!!!!!!!
2Curious4WFC
« Reply #75 on: November 19, 2008, 03:08:54 am »
I am new here on this forum, there are great discussions going on here.
If I may add, a scope and sweep function generator may work just as well
to find the resonance frequency.  Also I suggest to check out SPECTRALAB  ;)
Cheers
« Reply #76 on: November 19, 2008, 03:15:29 am »
Welcome 2curious , great first post hope to see 100 more .
I agree... what can we possibly tweak other than the freq once a pretty good quality coil is made  ?
This tool is too much for me... I'll try what 2curious said.
« Reply #77 on: November 19, 2008, 06:15:50 am »
When the operating frequency is raised the "distributed capacitance" starts to become significant at a point where L and C form a parallel resonant circuit as in "B".....
this statement about chokes is what i need to accomplish with my charging choke......i have it i just need to find the frequency.....each choke consists of 3 things......resistance R, inductance L, and capacitance C......the choke has it's own resonant frequency.....where the proportion of resistance, inductance, and capcitance is in perfect hartmony....the choke is resonating........with the windings in bifilar form this will also enhance the overall high voltage output......then we just apply this resonance to the wfc and we have our vic......in its early stages it might only be capable of  voltages in the 1kv range or less.......but as long as it works as stated in the patent then it works......think about a stun gun......it uses a pulse circuit powered by a 9 volt battery sends it through a tiny transformer and into a capcitor where the electrodes are discharged on a person.......the tiny transformer is created to make voltages in some cases around 1,000,000 volts while holding back almost all amps so the person is severly stunned but not killed.......this concept is exactly what we are shooting for......and a resonant charging choke is capable of producing high voltage levels.....and a bifilar wound choke with a capacitor in between will produce 250,000 times greater than a normal inductor........this is where everything adds up.......
i am getting help on calculating the point "B" from a very intelligent individual from an electronics forum.......they have mention things which i have already come across in my studies.....hopefully they will be able to help me calculate this frequency without the use of a frequency sweep.
stay tuned......this is for the world.
« Reply #78 on: November 19, 2008, 22:57:28 pm »
so i just got 3 books from the library which have crazy insights and parallels to meyers......i would love to scan each and every page but i would end up scanning the book.....RLC......is a magical group.....when i have time i will post my readings but as for now i am very busy.
« Reply #79 on: November 19, 2008, 23:07:47 pm »
alright so here is the aaron m replication....he offers all the right insight to connecting the bifilar coil......http://www.zshare.net/download/51610279d361f24a/...he also shows what i meant by naudins 1243 connection, which is the same as neogen, kevin wests, teslas, and meyers.
