Author Topic: unipolar pulse trains  (Read 99347 times)
tester
Re: unipolar pulse trains
« Reply #24 on: November 01, 2008, 00:56:47 am »
How about looking at where heat is being created. Take for example a single led light, a single resistor and a battery. Can you calculate where the heat will be lost, or consumed? Led, 600 Ohm Resistor, 12 volts. There is the solution to answer that question.
Where does the Power go, where is it consumed? Take a look at your circuits, is it what you thought?
How is it you can trick the energy directing it to where you desire, would then the fuel cell become part of the circuit? Is a fuel cell a condenser or capacitor? What exactly is a condenser used for anyways? Can anyone answer that? In the vic, can you calculate where the power is being consumed and in what form it gives? If so, why is the amp consuming device also generating power to be consumed, how is that possible?  What would be impossible, and what would not. If the device doesn't work as stated then it simply doesn't work because 1000 tried it many times, or maybe because the generating device was not generating because it cant or was not "functioning properly."
tester
« Reply #25 on: November 01, 2008, 03:14:14 am »
well i knowwhy my capacitor never rises higher than 30 volts becuase my wave form is a 50 percent stepped up unipolar pulse.....the inductor is not creating that second pulse as it is stated to.......so my water capcitor just charges discharges charges discharges.........over and over never reaching 40,000 volt states...hahaha.
here is where my shit just stops.
(http://i2.photobucket.com/albums/y2/kinesisfilms/yesnoshit.jpg)
once i can get the correct waveform out of this crap im convinced i will have it done....
i will go to an electronics forum.
Me and stevie has both seen square waves coming from a transformer. Sound impossible? Its not! Here is some other related material. http://people.seas.harvard.edu/~jones/es154/lectures/lecture_2/diode_circuits/diode_appl.html
« Reply #26 on: November 01, 2008, 09:27:20 am »
GUYS I DID IT!!!!! MY SHIT LOOKS IDENTICAL TO THE PATENTS!!!! I ACTUALLY FUCKING GOT IT.....OIAISHDHOASDHAHAHAH.....NOOOOOWWWWW ALL I NEED IS SOME SORT OF DEVICE TO FIGURE OUT INDUCTANCE CUASE I WAS USING MY 3.3 MILLIHENRY BIFILAR COIL AND THE ONE I WOUND MYSELF IS MUCH LARGER.....THE 3.3 MILLIHENRY INDUCTOR ONLY ALLOWS AROUND .043 MICROFARAD BUT THEN I JUST SLOWED DOWN MY PULSE VOLTAGE TO A LOWER FREQUENCY AND IT ALLOWED ME  TO  GO UP TO AROUND .23 MICROFARAD AND SINCE THE WATER CAPCITOR IS JSUT TUBES AND WATER I CAN CHANGE IT TO MEET HTE FREQUENCY ADN THE INDUCTOR BY JUST FILLING IT UP OR TAKING WATER OUT FOR NOW.......WAIT TILL YOU SEE THE OSCOPE SHOTS......MY SETUP IS SOLID STATE AND I USE AN AUDIO TRANSFORMER....I WILL POST EVERYTHING.....
THE REASON THIS WORKED IS LITERALLY BECUASE OF THE RESONANT FREQUENCY........THE ABOVE LINK ABOUT TANK CIRCUITS I JUST USED ALL THE MATH FROM THAT WHICH IS THE SAME EXACT MATH FROM THE PATENT BUT IN SIMPLE TERMINOLOGY......I AM HAPPY.
ahhh just found out how to measure inductance....sooo excited.
ooo one more addition to the post....i will make a video and put it on of my entire setup first thing in the morning........just so people can replicate it......
« Reply #27 on: November 01, 2008, 18:12:59 pm »
Hi kenisis,
Sounds good! I am looking forward to your videos and pics!
« Reply #28 on: November 01, 2008, 19:19:35 pm »
http://www.allaboutcircuits.com/vol_2/chpt_6/3.html
this is it.....i'm trying to get as accurately close to resonance....it's quite odd.......you really do need precision.....so resonance is the key and if it is slightly off it seems that it doesn't soar to high towards infinity.......but i am also using a 3.3millihenry bifilar coil.....which is reatarding this whole thing it only allows me to use a .063 microfarad capacitor.....i need to buy a 60 henry inductor off of digikey 2 of them at that......then we are talking......i have to go to work again i'm sorry i woke up late but JUST WAIT I WILL HAVE YOUR VIDEO!!!
« Reply #29 on: November 01, 2008, 20:46:31 pm »
awesome kinesis !!!
So your gonna get a bigger coil so you can work with a bigger cell ? that would be the logical next step.
tester
« Reply #30 on: November 02, 2008, 00:59:54 am »
i think you should stick with what you have and perfect what you have, then move on. Just my view after several move on's.
« Reply #31 on: November 02, 2008, 01:56:36 am »
alright this is another website that helped me out alot.....
