Author Topic: Stanley Meyers Resonate Circuit A Must See  (Read 42312 times)
Re: Stanley Meyers Resonate Circuit A Must See
« Reply #48 on: October 14, 2008, 21:42:02 pm »
The circuit  I posted shows the HV applied to the cell container and not to the electrodes.
« Reply #49 on: October 14, 2008, 23:50:08 pm »
After seeing the Videos i can say that this method will never run anything , it has no powert behind the pop .
this is what we should be aiming for
http://www.youtube.com/watch?v=chzk4Q7fa7k
tester
« Reply #50 on: October 15, 2008, 03:17:33 am »
i tried to point this out but i don't guess anyone understands.
The Ignition circuit, I have told everyone here that the coil is wrapped to restrict amps, i have uploaded videos showing this.
I have shown that when the magnetic field collapses, the Primary coil is wired in such a way that it more than increases the voltage by more than 25 times.
I tried pointing out that when the points open, it is only a source for the coil discharge to flow threw, completing the loop. When the coil discharges it is "PRODUCING" 300 or more volts from a 12 volt source, The capacitor in parallel with the coil "IS THE ONLY ELECTRONIC COMPONENT" that will allow the "LOOP"  -- "SUPER MEGA  MAGNETIZING THE CORE IN WHICH THERE IS A HV COIL THERE IN BETWEEN WHERE PRODUCED VOLTAGE DEPENDS ON MAGNETICS"
PUTTING A DIODE & CAPACITOR IN PARALLEL WITH THE HV COIL DISCHARGE WILL TRIGGER AN EFFECT THAT WILL BLOW WATER UP ON DEMAND.
I'm sorry i can not prove this to you now. But trust me, the circuit is coming and i do know what i am doing.
There is a guy on youtube, called gotus or something, unsure of the exact name. He shows a similar setup to what i am referring to using only an ignition coil and capacitor, "My setup will be much stronger then his." And his isn't that bad, he is actually showing very good results for blowing water up, "im not sure he understands his own circuit." As i see what needs to be done that he did not do. It could do far greater than what its doing now.
If you know who i am talking about, That circuit want compare to the one i'm working on, and the good part, there is no mods needed to install it on the car, unlike the way they have it now.
This guy's circuit can be found at overunity.com, take a look at it. I think i can do much better Thanks to this guy sharing his work.
tester
« Reply #51 on: October 15, 2008, 03:27:06 am »
I probably agree about the parallel coils, check out gotus on youtube, you may have to go to overunity.com to find the link. It makes good pops dankie. But yah, not sure whats up with dingle LOL.
« Reply #52 on: October 15, 2008, 04:11:04 am »
hello everyone i think it is gotoluc and not gotus
ty rgds paul
tester
« Reply #53 on: October 15, 2008, 05:07:59 am »
ty rgds paul
Thank you! He is highly credited for sharing that circuit. When i post the updated schematic it would take me 30 pages to explain to you guy's why it is wired the way i will have it.
The thing is, it should be understood that the spark gotoluc is getting is weak. He is not using the discharge cycle of the ignition coil to magnetize his core, the primary of the transformers main POINT is to take what ever voltage you put into it and step it up over 25 times. However, his coil never gets to the discharge cycle, instead his capacitor fires.
Yes, it is a capacitor discharge spark, even though the guy's say it isn't. I have the knowledge to make this circuit very very nasty.
tester
« Reply #54 on: October 15, 2008, 07:52:04 am »
For the guy's that's watching this post and already have their setups working, you're welcome to test out this circuit before i have the chance to. As i am waiting on my diodes and bridge to arrive.
Here's the "Amp Tank" circuit i will be working with. If you test this, please drop by and give feedback.
« Reply #55 on: October 15, 2008, 08:24:59 am »
OK, I understand what is going on now. Awesome work!!!
The only thing I wonder is if this could really be used on a car and produce enough power at the same time?
I also wonder, did Stan use this in his car?  And if he did, then what was the purpose of the air processor?
