Author Topic: Stanley Meyers Resonate Circuit A Must See  (Read 42311 times)
tester
Re: Stanley Meyers Resonate Circuit A Must See
« Reply #32 on: October 13, 2008, 14:48:21 pm »
The auto coils is about 1.2 to 1.3 ohms.
My new coils is 1.8 to 1.9 ohms, this is just a test.
Here is how i wrapped my coil.
58
57
54
52
50
43
tester
« Reply #33 on: October 13, 2008, 15:48:25 pm »
The spark is louder and it does pop. It is much more hotter compared to my factory coil results i got yesterday.
The capacitor is underrated or something, yesterday this capacitor worked great, today fire jumps across the points. This tells me i have a hotter spark as well. Putting capacitors in series makes it worse! Something is not right with the ratings of the capacitors, unsure what this may be at this time.
If you listen, the popping is the amps in the primary  being discharged onto the plug threw the path of the capacitor, ("thats what the caps for. a path to stir volt amps away from the points"), if it was only voltage you was hearing it would not be popping. This is just another demo coil, i am looking forward to a much nastier coil soon!
Fiditti
« Reply #34 on: October 13, 2008, 17:18:33 pm »
Hydrocars,
Nice to have you sharing with us.  This is great stuff.
« Reply #36 on: October 13, 2008, 18:31:22 pm »
I`m not sure about this , i dont think this is the right method to blow up water violently , after Dynodon confirmed that the VIC was all in 1 and small enough to fit in the injector i think it has to do with something else....
I thought it was obvious to everybody that to blow water up violentrly , like really violently , not just some weakish plasma explosion that cant move nothing .
tester
tester
« Reply #38 on: October 13, 2008, 20:52:02 pm »
Danky, i think the power behind this circuit is gradually sinking into the public mind. I cant really explain it any better than what i've already done. As it only has 3 simple components it should not take 2 pages to explain its workings.
It is truly a powerful circuit. I will leave it at that for now.
Meanwhile, i have to scale this circuit up, and until i figure out why my capacitor got underrated so quickly, i am stuck, the video could have show a much nastier pop, "I had it turned down because the coil thumps," and i didn't want the back emf smoking my last fet.
« Reply #39 on: October 13, 2008, 23:22:06 pm »
58
57
54
52
50
43
Great stuff Mr. H!
