Author Topic: What if?  (Read 2467 times)
What if?
« on: October 11, 2008, 07:47:19 am »
What if the constant displacement pump/static filter from figure 3-45 worked with a VIC just like the cell . And what we saw was a cross-sectional view . And that there were circular electrodes and the impurities would just turn forever around it.
« Last Edit: October 12, 2008, 03:20:52 am by dankie »
Re: What if?
« Reply #1 on: October 11, 2008, 14:00:33 pm »
I wont explain much , ill say this after Dynodon said the coil was 3 inches long  and 1.5 inch wide i had this wild idea , so this is small right?  and we got this compressional waveguide injector right? , What if......
http://waterfuelcell.org/phpBB2/viewtopic.php?t=1157
http://a0.vox.com/6a00fa968f29f2000300fae8e41418000b-pi
http://www.youtube.com/watch?v=Vd3UOM7is10
http://www.zpenergy.com/modules.php?name=News&file=article&sid=304
Hi Dankie,
Thanks for this great view on things.
Well, what can i say.
I seen the videos of Peter Lindemann with prove of these longitudinalwaves and i was impressed by it.
When you tune into resonance, you will have a higher efficiency.....so it seems.
After seeing all this and the VIC and the injector again, it snapped into my head.
Normally that means something good is coming out of it. ;)
What do we see here on that injector Vic part?
Compare  this with what you see on the Xogen patent.
2 electrodes
1 trafo with a prim and a secondairy coil
on top of the tubes 1 big coil...
Maybe it is true that a pulse magnetic field changes the hydrogen from ortho to para..
Again, just some food for thoughts
Re: What if?
« Reply #2 on: October 11, 2008, 21:30:00 pm »
Dankie,
The attached video is from Eric Dollard and Peter Lindemann.
They prove and show the longitudinal waves.
The coil on top of tubes is shown here in the Xogen patent.
http://www.ionizationx.com/index.php/topic,407.105.html
Have fun downloading!
Re: What if?
« Reply #3 on: October 15, 2008, 22:04:11 pm »
Hi Dankie,
well, those are my thought too.
Not sure if Stan used longitudinal waves, but it think they could be used.
Re: What if?
« Reply #4 on: October 16, 2008, 00:00:42 am »
i have never heard of his coil being situated under his electrodes.....and if your referring to xogen the coil was above the electrodes and had nothing to do with scalar waves....the coil is physically impossible to create scalar waves it did induce a magnetic field in pulses and nothing more......now if we puta cadecus coil over or under our electrodes this might support what your saying.
