Author Topic: Insisting on the importance of the Taper resonant cavity  (Read 1679 times)
« on: August 11, 2008, 21:34:29 pm »
So I must insist on the importance of this geometry .Theres no specific size for the injector , only that the distance between the two cones are .01 inch to .06 , it was small enough to hold the water by capilarity ,i believe and that it was small as show in the videos of him holding the injector. Stan suggests about a 4.5 ratio or more from the beginning of the taper to the end tip , whats funny is that the geometry acts as a "natural step charger" ..This isnt the right terminology i know , but lets say the beginning area of the taper is 10mm diameter and the end is 2mm diametre ,Then the voltage will be stepped up from 10,000 to 50,000 following the exact same ratio as the taper itself. The gap distance between the two cones always stays the same. Anyways.... everybody should read the first 2 pages of section 6, for me its pdf page 131-132 of the SMTB . In his statement he assigns letters from A to D to every section of the taper . As the water travels through section A to D it is seperated into HHO , the electrons of the atoms are sent to a higher energy orbit untill 4 electrons of the oxygen atom are stripped away near the end tip . As it is expelled outward past secton D is explodes with high energy because the atoms cant recombine , all that without without damaging the cell in any way since they are exited out beyond the cell acting as a quenching circuit at the same time . So this is like a laser energizer / electron extraction all in one without the painful unspecifics of where should the LEDs be?, what LEDs to use? , Where do i put this fukkin extraction grid? The taper solves all these , Above all , its fairly simple geometry to have machined and requires less material.
here is a picture of what exactly is a taper
http://www.mediafire.com/?tje2ontnmcw
« Last Edit: August 26, 2008, 05:04:25 am by dankie »
Re: Insisting on the importance of the Taper resonant cavity
« Reply #1 on: August 11, 2008, 21:48:11 pm »
there was 2 clear techniques in would say , there was the *mass gas production and send it the the engine* , and there was the *instant explosion of water for over-unity kinetic energy yield*
« Reply #2 on: August 11, 2008, 23:38:22 pm »
besides the shitty explanation and incorrent terms all was okay  , and the fact i didnt understand wtf you were saying
hahaha everything was a little weird untill  "The water level remains constant in that it has two chambers one spilling into the other like a waterfall"
then i went lol , wtf 2 chambers??? it goes around you dummy , its a cross-sectional view!!!
