Home
Help
Login
Register
Electronics
Electronics
Other
connecting right?
Print
Pages:
1
Go Down
Author
Topic: connecting right? (Read 2599 times)
Login to see usernames
Hero member
connecting right?
on:
July 23, 2008, 04:00:31 am »
alright i have aquired an ei core type step down transformer that i am using in reverse.....it's primary is 230volts and its secondary is 12 volts....every tiem i try to connect it i get huge sparks at the terminals.....so i just hooked it up and flipped the switch on my pwm......it gave a good 2 second go then hissed and smoked.....i think i blew my mosfet....i have my pwm to transformer hooked up as the following picture below.....are my connections wrong or is this type of transformer no the right type....it is meant for ac current but i am pulsing the dc soo.....it's also a single phase transformer....
(http://i2.photobucket.com/albums/y2/kinesisfilms/pwmshortcircuit.jpg)
Last Edit: July 23, 2008, 09:21:27 am by kinesisfilms
Logged
Administrator
Hero member
Re: connecting right?
Reply #1 on:
July 23, 2008, 10:00:46 am »
I had the same thing some weeks ago. You must start at a very low frequency with pulsing.
like 10hz.
My toriod trafo didnt like frequencys higher then 1 khz at the end......
Above that, you will short out everything!
Hopes this helps
Br
Logged
Hero member
Reply #2 on:
July 23, 2008, 21:13:11 pm »
hmm i see.....when i use it as a step down transformer it seems to work perfectly...but only in reverse does it bite back...thank you though....i am just going to repair it and build another one.
Logged
Administrator
Hero member
Reply #3 on:
July 23, 2008, 23:24:46 pm »
yeh, you better have some FETS on stock...you will need them!
Master FET killer
Logged
Print
Pages:
1
Go Up
Electronics
Electronics
Other
connecting right?
