Author Topic: Water Jet cut SS plates, any size. $  (Read 6160 times)
« on: June 22, 2008, 03:19:11 am »
There is a guy on ebay who sells water cut plates of any size.
You can seek him    :
historcorp
Re: Water Jet cut SS plates, any size. $
« Reply #1 on: June 22, 2008, 04:38:53 am »
Which guy on ebay? Seller ID and item number?
bigjgarr
« Reply #2 on: June 22, 2008, 19:36:24 pm »
Here is the auction number and item he is referencing #180256620660
« Reply #3 on: June 22, 2008, 22:37:02 pm »
 We have been bandsawing 304 for the past 15 years. Bi-metal blades, and SLOW blade speed, and WAX the blade as you cut, and you can saw .065 all day long with a bandsaw.
« Reply #4 on: June 22, 2008, 23:03:09 pm »
Good info. How many teeth belt you using?
« Reply #5 on: June 22, 2008, 23:05:08 pm »
If you contact him, he will make custom size however you want.
He said he could even cut an image in the steel with 0 distortion.
It is expensive though, he charges by the: 1"x1"
« Reply #6 on: June 23, 2008, 01:35:27 am »
  18.  NO skip tooth or anything different. Just small teeth. HAVE to run the blade speed SLOW.  We buy the coils from Do-all and weld them ourselves.
« Reply #7 on: June 23, 2008, 06:21:31 am »
I bet the band saw works perfect for cuting tubes also. I've been using a chop saw and or a pipe cutter. The pipe cutter does great on the inner tube but on the outter tube its no good because of the way it pushes the blade into the metal to cut it...
I'm going to fit my small band saw with a new 18tooth blade.
