Author Topic: Stanley A Meyer Steam Resonator  (Read 202 times)
« on: July 28, 2023, 11:09:10 am »
Stanley A Meyer constructed a Steam Resonator
see attachment.
    • The Legacy Of Stan Meyer
Re: Stanley A Meyer Steam Resonator
« Reply #1 on: August 16, 2023, 14:45:20 pm »
What publication was this from?
« Reply #2 on: August 18, 2023, 07:21:07 am »
The steam resonator was part of his last patents that expired in 2012.
It's incredibly simple...it's two identical ungrounded transformers with their primaries wired in series. The secondaries are attached to stainless steel plates, and the plates are overlapped in such a way to block their current paths, and still impinge an oscillating force on the water molecule. Basically the closest opposite polarity electrode is from the other transformer, so no direct ionic connection can be made across either transformer's secondary, so the load is only the primary current draw.
If I remember correctly it's like this....LXLS=Left transformer left secondary wire, RXLS=Right transformer left secondary, LXRS=Left transformer right secondary, RXRS=Right transformer right secondary
                     First 1/2 cycle
 (transformers wired with same polarity primaries)
LXLS     RXRS                  LXRS     RXLS
                Second 1/2 cycle
LXLS     RXRS                  LXRS     RXLS
                            Or
                   First 1/2 cycle
 (transformers wired with opposite polarity primaries)
LXLS     RXLS                  LXRS     RXRS
                    Second 1/2 cycle
LXLS     RXLS                  LXRS     RXRS
Edit: had the polarities mixed up, fixed
(The like charges in the middle repel the ions trying to go to the opposite side of their respective circuit...as the electrode plates are close together...say, no more than a centimeter apart...more like 5mm I recall from the disclosure photos)
« Last Edit: August 18, 2023, 11:15:56 am by Radiant_1 »
