Cn,can you confirm that the extra bubbles are just vapour?brsteve
What kind of vacuum pump? Try this: Impact Instrumentation (Caldwell, N.J.) MDL # E-12, 12 vdc, 8.0 amps. You'll need to put a pot on it to control the speed. It will pull over 30" HG. Used in ambulances for pure oxygen. Works great! Make sure you use reinforced tubing. Voltar
Why not just super heat the water under a pressure above the xombustion engine, and release the fuel in the combustion chamber so it can convert instantly from a liquid to it's gas form?https://en.wikipedia.org/wiki/Joule%E2%80%93Thomson_effectI refferanced the Thomson effect thinking steam under a huge pressure drop would freeze or is it the other way around?
