Author Topic: Did Meyer Use Two Frequencies?  (Read 3447 times)
Re: Did Meyer Use Two Frequencies?
« Reply #16 on: January 12, 2022, 13:06:01 pm »
Sorry again.  I wasn't demanding discussion; I just felt it was a little rude to ask me to post something, then blow it off.
If you want to find the resonant em frequency, take the MEV value of the reaction, then convert it with Boltzmann's Constant.  Every voltage has a corresponding frequency, every frequency has a wavelength,  every wavelength has a temperature.
The forums are quiet?  The time is coming when only the Trolls are left, waiting for someone to say something important, so they can jump in with an overwhelming distraction.
And I ain't your ET.  Me Human.
Over and out.
« Last Edit: January 12, 2022, 13:28:16 pm by electrotek »
« Reply #17 on: January 19, 2022, 21:30:22 pm »
The point of this whole thread is to find out if anyone saw Stan's setup with two VICs.  I saw two EPGs under the dune buggy hood.  And that 'pickup coil'  being slightly smaller than the primary, could easily be switched in as a higher frequency driver winding.  That higher, substitute pulse frequency could be switched in during the 'supposed' relaxation time.  Any free electrons could be extracted with the top ring and a different circuit.
« Reply #18 on: January 20, 2022, 05:25:39 am »
Check with Bob Boyce  I think one of his early devices output  had a 3 frequency output for use in the early plate HHO generators
regards
« Reply #19 on: January 21, 2022, 00:20:38 am »
regards
Thanks, that's completely new to me.  I'll check into it.
« Reply #20 on: January 21, 2022, 10:14:31 am »
Bob used 3 frequencys, yes.
The bob setup in a couple of words:
He used a bias DC voltage of 1.3v a constant strait DC.
The pulses of the three frequencies are very very short pulses. The theory is to use non herzian charges.
These scalar waves are very good in charging water....
cheers
    • The Legacy Of Stan Meyer
« Reply #21 on: December 06, 2022, 01:08:46 am »
Actually, Bob used 6 frequencies. Each of the 3 channels, had a Gated Pulse waveform. And, if you've ever listened to your electricity, you'll hear both tones being reproduced and can tune to combinations that produce musical chords.  :)
Then, of course, the shared toroid and LC tank were subject to hetero-dyning as well. Exponential harmonics are created from that effect. I built a 4 channel version, similar to Bedini/Rife 4wave mixer. Ironically, it's the same exact process of modulation.
What's the difference between Gating and Amplitude Modulation?  1 picoVolt :)
Stan's use of gradient voltage bursts, effecting Resonant Action in the spherical cavity, were also a form of tonal modulation. Leo Fender did it in 1970  with the infamous Bias Wiggle :)
Solid State Version: https://www.youtube.com/watch?v=-vXpCsLjlgE
Vacuum Tube Version: https://www.youtube.com/watch?v=7S1R55vmYcA
Listen to your voltage
