Author Topic: Stanley A Meyer Multi-Tier EPG Part List and Designators  (Read 536 times)
« on: March 08, 2021, 17:21:26 pm »
Multi-tier EPG Build Listing  6TMaggasEPG     mod 5    listing in progress
COPPER AND PLUMBING
Quantity         Description                                         Part Designator        Materials
 6                     Spiral Tier                                          ST        300 cm tubing per tier
 6                     Inter-tier Tube                                    IT        22 cm each connecter
14                   45 Degree fittings                               ITF        2 for each IT
1                      Recycling tube                                   RT        1
1                      Top Feed tube                                    TFT        22 cm
1                      90 Degree fitting                                TFTF        1    * Recycling tube is greater diameter  fitting harder to locate if 45 degree option
4                       Linear  Pump fittings                        LMPF        4   to connect linear mag pumps to  RT
2                      Taper Fittings                                     TPF        2 for vacuum evacuation and  gas/slurry fill
2                      Magnetic pumps                                 LMP        for  gas/slurry movement
1                      vacuum pump
Wire               22 ga AWG                                          IWW        inductor windings
                       28   awg                                               ACW        alignment coils
qs                      0  awg
                        4  awg
                      10-12  awg                             Romex(r)  3 conductor/w ground
HARDWARE
          1 Plywood base for 7T gega Perspex for the 6T model  use the Perspex  40 x 40 cm,  for plywood  larger to accommodate EEW ass'y
                       8 power connectors
GAS
                Quantity of  gas required is pressure dependent, evacuate spiral core first  open fill valve  FV2 for gas introduction
                for ferrofluid models measure out calculated fill volume for device and introduce from bottom slowly  use2  inline
                fluid traps before vacuum pump
ELECTRON EXTRACTION WELL (EEW)
6          Porcelain  Light Bulb fixtures
6          Square metal outlet boxes
1          stepping switch                                     to increase load on warm up
6          Incandescent Bulbs 100 or150 watts    depends on amount of energy to be dissipated in electron extraction well (EEW)
        do not use LED bulbs , they are too energy efficient!
qs        Mounting hardware                               screws/bolts
« Last Edit: April 16, 2021, 14:32:29 pm by jim miller »
