Author Topic: Stanley A Meyer The Magnetic GEL EPG  (Read 527 times)
« on: March 07, 2021, 20:02:55 pm »
It is well known that Brownian movement can suspend small particles of solids, such an in muddy water
or small fat globules as  milk. In this  novel  approach to energy generation, Permanently
magnetized particles, and materials that that exhibit paramagnetism such as the transitional metals Fe, Ni
and Co are suspended in a liquid clear optical adhesive, a clear methyl methacrylate, Castolite(r) or
one of the glass hydrogels and clear SillyPutty(TM)
In the case of the clear optical adhesives a uv light hardens the adhesive
and the suspended magnetic material or magnetizable media is now
held in a fixed position  (good way to make custom shape magnets)
In the case of the casting resins the hardening agent is acting like the uv light
During this process the gentle rotation of the reaction vessel can prevent settling before the
plastic or glue "sets" or solidifies
By proper selection of the viscosity and particle size,  rate of sedimentation of nano magnetites
of the 10nM size or metal powders on the order of 50nM is not a factor during the hardening process
By injecting the casting resin or viscous optical glue into the spiral configuration  of copper tubing
you now have a clear non-settling magnetics or matrix of magnetite and/or magnetizable  particles
Now you have a tube that laser light can pass through in a pulsing manner, causing changes in the
magnetic flux in the pick up coils surrounding the light guide. Lenz law is not an issue since the magnets
are not moving , only the magnetic pulse wave in a linear and radial fashion.
The amount of Flux is dependent on the number of coils, the number turns, the length of the tube or
channel,  and the frequency   Because the amount of magnetic susceptibility is dependent upon the
concentration of the particles because of light scattering, the  vol/vol ratio of nanospheres must be
low but first surface mirroring with chrome or silver plated  conduction channel the light energy
is re-reflected within the channel   Also manipulation of the index of refraction can reduce  losses
of light energy And by increasing the frequency of pulse 400Hz the cloudiness of higher concentrations
can be offset to some degree
It's roughly analogous to a ruby crystal laser but in this case the energy is affecting the magnetic field
of the transitional metals and/or the paramagnetism of nanospheres of magnetite used in EPG power generation
In general the higher the viscosity of the suspension phase, the lower the sedimentation rate of  particulate matter
The smaller the size of the particulate size, the lower the sedimentation rate
In the ferrofluids  the typical  particle is 10 Nm in diameter and  Brownian movement can keep the small particle is suspension for
long periods of time  especially if coated or in the prescience of a surfactant
So this led to investigation of  more viscous  liquids as  Syltherm silicone oils, polyethylene glycols, and hydroarbon oils similar
to  kerosene for the oil phase of the ferrofluids
The fact that nanorods of iron or magnetite are large enough to have a discrete north and south pole s( nanobar  magnets )were then possible
Circulating aligned  polar magnets seem to be part of the solution to the EPG generators
Tip: Select frequency of laser with attention being paid to the absorption bands of the clear medium
Pat Pend says hello
sandia24 thanks
thanks to Aaron for the goo the couldn't be given out in Bremen last year but the reduced
viscosity concept put the research on the right track
« Last Edit: April 19, 2021, 16:19:32 pm by jim miller »
