Author Topic: New information  (Read 2709 times)
Re: New information
« Reply #16 on: March 27, 2021, 08:14:07 am »
so what did you do with the original secondairy coil?
Did you remove it from the vic?
Just use the two choke coils as secondairy, or wrap a bifilar coil and use it as a secondairy?
I am happy that you still try to uncover the vic, Brian!
Yes, you have all that correct, then I dropped in the secondary and got that secondary smoking hot.
did it vanish and appear on the other side of your house? :)
Smoking hot? That looks like Eddy Current effects to me.
It like move a magnet very quick in a copper tube.
What might have happend in your vic, is that your secondairy coil was out of phase with the rest of the vic.
Meaning, that the magnetic field that your secondairy coil had, was changing in opposite direction of the magnetfield of the vic core.
Thats like friction.
Maybe you should try winding your secondairy in the other direction........
here a video, which i trully like very much for years now.....It shows magnetic heating
https://www.youtube.com/watch?v=NivItikx0AU
Re: New information
« Reply #17 on: March 27, 2021, 08:46:59 am »
I was using a shunt capacitor as well
between what?
Re: New information
« Reply #18 on: March 27, 2021, 08:50:29 am »
Primary
Re: New information
« Reply #19 on: March 27, 2021, 09:44:50 am »
Primary
So you where trying to create resonance on the primary?
Re: New information
« Reply #20 on: March 27, 2021, 17:15:40 pm »
It's not really a resonance Stevie it's more of a biffler choke on each side of the secondary that causes amp restriction. The only problem I seen according to Stan is the voltage across the cell is low but the production is massive while the primary coil is very very low wattage compared to the output and hydrogen you get.since you seem more interested than I thought you would be I will go ahead and add, the primary coil is actually made from the primary winding of a microwave oven transformer that is where I stolen the wire from also that is the same size wire the chokes are made from the secondary is of greater size wire around 26 gauge I believe it was, the resistance something primary coil was about one ohm I believe it was as so with the jokes. My goal was to further alter the primary due to only having around 200 wraps for a primary this was all done on a quarter inch in diameter by 4 in Long ferrite bar.
