Author Topic: I Cracked it!!!!  (Read 7555 times)
Re: I Cracked it!!!!
« Reply #72 on: June 13, 2020, 23:08:33 pm »
I still haven't had time to get back to any post here but I will in time maybe a week or two. I'm deep in politics at this moment and at this time I have poweful people coming into my home monthly and looking around and there's nothing I can do about it. I was told if I gave any trouble or refused anything my children will be put in a foster home and taken away from me so at this time I am being threatened, I am not the kind to let stuff like this slide so simply put I will not be hushed!
« Reply #73 on: June 28, 2020, 21:32:40 pm »
I did some tests in this direction few years ago..  i was hoping that the cells were going to create a current that would sustain...
did you tried morephases it was going to be my next step than at the time but i had many theories to go and test less than 10_% of them ...
i would get a acrylic cup sand it inside and outside and apply some graphite from a pencil like on the outside and than place an aluminum foil on outside...
you will see a much more pronounced effect and more
you will see the gas bubbles flying around the top really moving...  at the time i pulse it with a step up transformer than i had this two diodes on both sides of the transformer going to two coils and connecting coils to the cell.. one side of the secondary was connected to the foil on the outside...
today i would connect a center tap of the secondary and see what happen...
i was very busy trying to develop a medical device for this covid 19 emergency and i came up with a very nice monitor of pressure flow and volume that might be use full for our experiments and is way cheap to build... i will give all the code for it open source on my google drive here for you guys .. the whole pulmonary ventilator is almost ready but the code is already useable... just need few tweeks and is done.. it just need a powersupply, sensors, a esp32 controler and a nextion screen... it can also command servos to control flow, open close etc... hope you enjoy =D
im trying to put things together to do some test too soon... this project will end soon with goodnew i hope!
« Reply #74 on: June 30, 2020, 16:44:55 pm »
I'm glad to hear you are a coder sebo. Unfortunately I code in assembly which I find the easiest understood and the most straightforward not sure where you use. I have written a cold for the atmel AVR in atmel studio and I have been able to monitor a coils Behavior. It is very strange you bring this up because I was going to post this today anyways. This chip I have program monitors a coil and I have found that to get a coil to resonate you have to send square waves only not triangle not sine waves to get the coil to resonate at itself frequency. I would like to share this in case I died or something and I want this pointed out and I want special attention brought to what I am about to say. So please give the following special attention.
When you pulse a coil and you see a ringing wave after the square wave and they are perfect ringing rigs that is that coils resonant frequency. They can call it ringing all they want and teach that it is indeed ringing and not a resonant frequency but I decline 2 agree with such rubbish. As a tester an experimenter I can tell you the ringing frequency is a self resonance they coil is behaving at.
I will also share a coil does not like for the resonant frequency determined by the Bell ringing to be reproduced back to itself it is stubborn like a mule. I have obtained and recorded a coils resonant frequency and replicated that frequency and played it back to the coil to ring that coil and they coil will refuse to respond. I have found that just about a square wave at a very wide range of frequency will cause any coil to ring in this way especially around 100,000 Hertz of a square wave. This is indeed the latest of my findings and I could have never found this if I would have never programmed the atmel AVR are to help me pinpoint where residents is in a coil so this I do share.
I found the following video on YouTube the very start of the video shows you what ringing I am referring to I'm not sure what the rest of the video is about.
https://youtu.be/Ky2T1-n_Fks
« Reply #75 on: July 09, 2020, 06:09:07 am »
I had some equiptment malfunction, so i'm not sure sure the above post is exactly correct on the bell ringing, Im limited on time. more on this later.
« Reply #76 on: July 25, 2020, 11:35:42 am »
If you see a ringing after the pulse, you must find out the reason.
I have seen ringing because of the capacitance of my mosfet.....
Thats why i recommand everybody to use the good old 2n3055 transistor..
Forget that shitty mosfet.
    • The Legacy Of Stan Meyer
« Reply #77 on: December 06, 2022, 03:25:46 am »
