Author Topic: I Cracked it!!!!  (Read 7587 times)
  • Build it. Power it. Use it.
Re: I Cracked it!!!!
« Reply #32 on: May 10, 2020, 22:29:00 pm »
My unit is getting close to the testing phase.  A lot goin on, but if I can squeeze one thing in each day on this, pretty soon it'll be sitting there.
I verified the fluorescent driver works, and the flashlight LED assembly is ready.  I dug out a relay which looks like the one in the video.  It's rusty and getting the little steel plunger out will be about the last challenge.  Then it's just wiring it up to a cell and seeing what happens.
I can see a lot which might be done with this new circuit, and I may even test my new single-phase shape resonance diode.
« Reply #33 on: May 11, 2020, 19:58:49 pm »
I am glad someone is testing a transistor my only Wonder is a mosfet is voltage controlled and very sensitive to the resident of feedback of the coil and the transistor is current regulated at is Skate rather than voltage like the mosfet. Maybe this will work out better let me know.
« Reply #34 on: May 11, 2020, 21:14:57 pm »
It works now much better.
I got some highfrequency switching high power transistors....
That works!
The circuit is still a little onstable, but stable enough for the coming tests.
Here another video...
A 8 watt tl bulb goes fully bright
The circuit does 18v on 0.3 amps.
When i touch the solder on the plus wire, i get jolt...
See also how the bulb is still shining when it goes over the batterys...
As the whole circuit goes Tesla....and radiates...
https://youtu.be/woFbQ7daPB8
« Reply #35 on: May 12, 2020, 17:34:28 pm »
https://youtu.be/1ZTbuofn4hQ
I burned my skin...
First hho from 1 wire
And more wierd things...
« Reply #36 on: May 12, 2020, 17:49:25 pm »
And then i saw a stream of hho...and then the batterys got empty....
I will get a powersupply in here.
« Reply #37 on: May 12, 2020, 18:55:09 pm »
And there it is...the old works best...
Do you want to see HHO production Tesla style?
Watch this... 9volts and 0.4amps
https://youtu.be/_7pulpUl4Mg
« Reply #38 on: May 13, 2020, 20:15:23 pm »
Hell yeah! I'm impressed!!!
« Reply #39 on: May 13, 2020, 22:12:36 pm »
The next question is......what to do next...
