Author Topic: I Cracked it!!!!  (Read 7562 times)
Re: I Cracked it!!!!
« Reply #16 on: April 27, 2020, 04:50:16 am »
« Reply #17 on: April 27, 2020, 06:32:39 am »
« Reply #18 on: April 27, 2020, 13:11:58 pm »
Brian, those are very very cool test,s you did.
I am proud on you. Never give up, i would say.
You are the first showing high voltage on the electrodes of a Meyer test setup.
I never seen anything like this before.
My comments : i think that your coil between the cell and diode, is picking up power from the secondairy.
That closes that part of the circuit.
Question: can you try separating the cell with diodes and coil , from the high voltage transformer?
Just use a long wire between them.
At least 2 meters would be good.
I wanna know if you see bubbles with that distance..
Man....!!!! Wow!!! Those sparks show a voltage of at least 10kilovolts....
« Reply #19 on: April 28, 2020, 17:13:54 pm »
I finally fried that mosfet last night the one in the video I believe it's a 13 45 or something another of that nature anyways I compared it to another one by installing another smaller mosfet like seen in the original videos let me tell you what those small mouth puts blow almost every time the resistor and one of the original videos was in the wrong place I was only following the meaning Tesla circuit eventually figured it out and moved it over from the gate to the source it's a 1 million Ohm resistor and that is where it belongs however sometimes I have to put my finger on the resistor to get the circuit 2 resonate. Also I was able to light a 12 volt light I'm the secondary call by connecting a lot between. Cole and the primary I'm talking about the coal in series with a fuel cell the secondary call lead what's left on connected on one end and I was arcing it on either of the other call that was in series terminals and with a right Arc a 12 volt light will light and the amp draw only went up 20 ma.
 I do believe this circuit should be used to convert energy and not for a fuel cell I think the fuel cell is connected too soon in the circuit I also think this should be a wireless system with that being said you could now draw and imaginary circuit were they fire stats in resonance in the second goes to the fuel cell I believe this will give you the full 360 Degrees rather than the 180 degrees I feel like I am getting now. Sorry sorry about the typos it is a text-to-speech cell phone error it's either that or not posted off sitting in the parking lot of a doctor's office. I have many formulas I have gathered up over a great deal of time reading and researching I will scan these formulas if anyone is interested it is the master of resonance equations that I have put together one by one and they are all correct. I'll have all sorts of equations I'm about five sheets of paper I have taped on my wall if anyone wants them feel free to ask and I will post them somewhere here I will post them anyways like her own when I get time and if anyone has any problems with a formulas I will also post a how so you use them and anyone here that stuff used on the equations will no longer be confused cuz I will break it down really simple so everyone can understand how the form was work. Also also Stanley mayor has some form of in his patent and he says the dielectric properties of water is 78 arms meaning that is the capacitance reactance is 78 ohms with that being said it would only be true if the inductance reactance was also 78 ohms. Stanley walk Stanley walked around preaching 20000 cycles per second so with this and the end credits and capacitance reactance we are now able to check they circuit to see if it reacts is 78 or Twenty Thousand cycles per second using these formulas. I will I will upload a few videos on how to use these formulas to make it even simpler so if you've never done it before I will tell you now it's nothing don't sweat it these are very simple equations that I will teach you how to do.
One last night Tesla has some missing equations and I believe we can find them. If you if you search for Tesla on Wikipedia you will see patents in those patents you will see a energy converter that is on a round ring and in another patent you will see how he supplied the voltage with a twin to horse call where it is not labeled that.  it is possible whoever stole the patents did not realize how powerful this patent was I think it is a leak. I will end this post saying Tesla's low voltage primary was very fine wire and the secondary was very coarse and it was wired on the outer side of the fine wire on a toroid. This is completely backwards from the Tesla coil. Also he does everything in sets of two's there is many different ways to hook the coils on the toroid as explained in the patent. Hey refers to this as a energy conversion machine that can be used in multiple ways and he Powers it with a twin horse coil. This is why I was saying one horse can pull 8000 lb into horse can pull 40,000 lb if you can understand that pick a pair that with these dual coils then you can make the equation they do not know enough to even attempt it at this time because all of these energy converting devices uses radio frequencies and not anything below 100 Hertz.
« Reply #20 on: April 29, 2020, 18:03:31 pm »
Hi Hydrocars,
If i understand you well, you say that the Tesla setup is creating more energy then you put in?
Its like opening a gateway?
« Reply #21 on: April 29, 2020, 23:38:40 pm »
Radiant energy Steve. I'm working threw resonance and Tesla's building resonator is related, I'm surprised what can be done with just 1.5 volts at the moment. I'm in deep research at this time. I will share all my findings.
I can't wait to see someone confirm this above circuit.
« Reply #22 on: April 30, 2020, 09:24:16 am »
You put 1 volt in that mini Tesla?
« Reply #23 on: April 30, 2020, 19:59:41 pm »
I doubt that, probably 35 I didn't measure, I haven't took anybmeasurements, I was so excited about hydrogen production with 1 wire. The wattage had to be low. I don't care if it was a hundred amps of current I don't care if it was 300 I'm just impressed with someone wire production...
